MMM-Fuel
Great idea !
YES !!! Look’s good! Wow! i will test it later. Thanks !!!
it works fine! Thanks a lot !!!
Perfect!!!
After @ostfilinchen reported an issue with missing leading zeros for some postcodes, I contacted the API provider but didn’t receive any response. So i fixed it myself.
[card:fewieden/MMM-Fuel]
Changelog:
Implemented voice commands to show the gas stations on a map with traffic layer
Hi @strawberry-3-141 ,
is it possible, to implement an delay so that i can start this module 2 time with different sorts? Otherwise can u implement more then 1 fuel sort?
Regards
Daniel -
@ostfilinchen will look into this
@strawberry-3-141: i’ve made changes in MMM-Fuel.js, node_helper.js, de.json and en.json. Now it works as it should.
The Parameter ‘type’ in the config.js must be now an array.How can i send you these files, so that u can implement in the original files?
