    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 541.2k Views 48 Watching
      bjoern
      it works fine! Thanks a lot !!!
      • W Offline
        WeedWood
        Perfect!!!
        • strawberry 3.141S Offline
          After @ostfilinchen reported an issue with missing leading zeros for some postcodes, I contacted the API provider but didn’t receive any response. So i fixed it myself.
          [card:fewieden/MMM-Fuel]
            Changelog:
            Implemented voice commands to show the gas stations on a map with traffic layer
            alt text
            • O Offline
              ostfilinchen
              Hi @strawberry-3-141 ,
              is it possible, to implement an delay so that i can start this module 2 time with different sorts? Otherwise can u implement more then 1 fuel sort?
              Regards
              Daniel
                strawberry 3.141 Project Sponsor Module Developer @ostfilinchen
                @ostfilinchen will look into this
                • O Offline
                  ostfilinchen
                  @strawberry-3-141: i’ve made changes in MMM-Fuel.js, node_helper.js, de.json and en.json. Now it works as it should.
                  The Parameter ‘type’ in the config.js must be now an array.
                  How can i send you these files, so that u can implement in the original files?
                    @ostfilinchen create a pull request on github or upload the files as zip
                    • O Offline
                      ostfilinchen
                      @strawberry-3-141 i’ve open an issue on github
                      1 Reply Last reply Reply Quote -1
                        Changelog:
                        It’s now possible to show
                        • multiple fuel types at once
                        • whether the gas station is open or closed
                        Have a look on the new config options: types, sortBy and open
                        Deprecated config options: type
                        Shootout to @ostfilinchen who did the prework for it
                        alt text
                        • 17
                        • 18
                        • 1 / 18
