    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 569.5k Views 48 Watching
    • strawberry 3.141S Offline
      [card:fewieden/MMM-Fuel]
      Changelog:
      Implemented voice commands to show the gas stations on a map with traffic layer
      alt text
      • O Offline
        ostfilinchen
        Hi @strawberry-3-141 ,
        is it possible, to implement an delay so that i can start this module 2 time with different sorts? Otherwise can u implement more then 1 fuel sort?
        Regards
        Daniel
          strawberry 3.141 Project Sponsor Module Developer @ostfilinchen
          @ostfilinchen will look into this
          • O Offline
            ostfilinchen
            @strawberry-3-141: i’ve made changes in MMM-Fuel.js, node_helper.js, de.json and en.json. Now it works as it should.
            The Parameter ‘type’ in the config.js must be now an array.
            How can i send you these files, so that u can implement in the original files?
              @ostfilinchen create a pull request on github or upload the files as zip
              • O Offline
                ostfilinchen
                @strawberry-3-141 i’ve open an issue on github
                1 Reply Last reply Reply Quote -1
                  Changelog:
                  It’s now possible to show
                  • multiple fuel types at once
                  • whether the gas station is open or closed
                  Have a look on the new config options: types, sortBy and open
                  Deprecated config options: type
                  Shootout to @ostfilinchen who did the prework for it
                  alt text
                  • Y Offline
                    yawns Moderator
                    wow, nice improvement!
                    • O Offline
                      ostfilinchen
                      Hi @strawberry-3-141,
                      can u insert the open-Parameter to the readme on github?
                      Daniel
                        @ostfilinchen it’s done must have forgot that one
                        • F Offline
                          FlorianRD
                          I didn’t need the “rotate Intervall”. Just sort by price (lower Price first).
                          How to modified the Settings for this result? Thanks
                          • L Offline
                            lolobyte
                            Hi, great job.
                            How to deactivate toggeling “rotateInterval:”
                            • O Offline
                              ostfilinchen
                              At the Moment there’s no Option to disable the rotate-feature.
                              U can open an issue on github to ask, if he can create this option.
                              • L Offline
                                lolobyte @ostfilinchen
                                @ostfilinchen Thank you, erledigt! ;-)
                                  strawberry 3.141 Project Sponsor Module Developer @lolobyte
                                  @lolobyte done
                                  • L Offline
                                    lolobyte @strawberry 3.141
                                    @strawberry-3.141 thank you.
                                    Very fast reaktion.
                                    It works.
                                    • O Offline
                                      ostfilinchen
                                      Hi @strawberry-3-141. I have an Issue with this module. My Mirror shows me no gasprice list. I wonder about it and so i check logfiles and so on. I also rebuild the string that get the request from tankerkoenig.de. The Response says: API-KEY blocked. Please contact tankerkoenig.de.
                                      On the website of tankekoenig u can download a logfile from our api-key. here i saw, that tankerkoenig get very often gets an request.
                                      [code]
                                      IP-ADDRESS - - [25/Nov/2016:06:28:21 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.008
                                      IP-ADDRESS - - [25/Nov/2016:06:29:50 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.017
                                      IP-ADDRESS - - [25/Nov/2016:06:30:07 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.009
                                      IP-ADDRESS - - [25/Nov/2016:06:31:47 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.014
                                      IP-ADDRESS - - [25/Nov/2016:06:33:08 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.012
                                      IP-ADDRESS - - [25/Nov/2016:06:34:04 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.015
                                      IP-ADDRESS - - [25/Nov/2016:06:34:36 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.011
                                      IP-ADDRESS - - [25/Nov/2016:06:34:46 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.016
                                      IP-ADDRESS - - [25/Nov/2016:06:35:06 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.013
                                      IP-ADDRESS - - [25/Nov/2016:06:36:36 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.025
                                      IP-ADDRESS - - [25/Nov/2016:06:36:50 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.009
                                      IP-ADDRESS - - [25/Nov/2016:06:37:06 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.008
                                      IP-ADDRESS - - [25/Nov/2016:06:37:37 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.011
                                      IP-ADDRESS - - [25/Nov/2016:06:39:05 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.020
                                      IP-ADDRESS - - [25/Nov/2016:06:39:18 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.021
                                      IP-ADDRESS - - [25/Nov/2016:06:39:24 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.016
                                      IP-ADDRESS - - [25/Nov/2016:06:43:21 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.013
                                      IP-ADDRESS - - [25/Nov/2016:06:44:51 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.028
                                      IP-ADDRESS - - [25/Nov/2016:06:44:51 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.032
                                      IP-ADDRESS - - [25/Nov/2016:06:45:07 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.013
                                      IP-ADDRESS - - [25/Nov/2016:06:46:47 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.016
                                      IP-ADDRESS - - [25/Nov/2016:06:48:08 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.016
                                      IP-ADDRESS - - [25/Nov/2016:06:49:04 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.011
                                      IP-ADDRESS - - [25/Nov/2016:06:49:36 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.010
                                      IP-ADDRESS - - [25/Nov/2016:06:49:47 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.017
                                      IP-ADDRESS - - [25/Nov/2016:06:50:06 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.018
                                      IP-ADDRESS - - [25/Nov/2016:06:51:36 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.027
                                      IP-ADDRESS - - [25/Nov/2016:06:51:36 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.031
                                      IP-ADDRESS - - [25/Nov/2016:06:51:53 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.011
                                      IP-ADDRESS - - [25/Nov/2016:06:52:06 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.017
                                      IP-ADDRESS - - [25/Nov/2016:06:52:36 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.017
                                      IP-ADDRESS - - [25/Nov/2016:06:54:07 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.015
                                      IP-ADDRESS - - [25/Nov/2016:06:54:18 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.014
                                      IP-ADDRESS - - [25/Nov/2016:06:54:25 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.011
                                      IP-ADDRESS - - [25/Nov/2016:06:58:21 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.025
                                      IP-ADDRESS - - [25/Nov/2016:06:59:50 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104
                                      [/code]
                                      Can u please look in the code whats going wrong?
                                      Regards
                                      Daniel
                                        @ostfilinchen did you may test something on your mirror and restarted it every time? can you post your config part of mmm-fuel?
                                        • O Offline
                                          ostfilinchen
                                          no, i don’t restart the mirror.
                                          here is the part of the config:
                                          	module: "MMM-Fuel",
                                          	position: "top_center",
                                          		api_key: "API-KEY",
                                          		lat: 51.282854,
                                          		lng: 14.109648,
                                          		types: ["e5","diesel"],
                                          		sortBy: "e5",
                                          		open: true,
                                          		radius: 16,
                                          		max: 3
                                            i will check it this afternoon
                                            • 1 / 9
