    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 589.6k Views 48 Watching
    • strawberry 3.141S
      After @ostfilinchen reported an issue with missing leading zeros for some postcodes, I contacted the API provider but didn’t receive any response. So i fixed it myself.
      [card:fewieden/MMM-Fuel]
      • strawberry 3.141S
        Changelog:
        Implemented voice commands to show the gas stations on a map with traffic layer
        alt text
        • O
          ostfilinchen
          Hi @strawberry-3-141 ,
          is it possible, to implement an delay so that i can start this module 2 time with different sorts? Otherwise can u implement more then 1 fuel sort?
          Regards
          Daniel
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @ostfilinchen
            @ostfilinchen will look into this
            • O
              ostfilinchen
              @strawberry-3-141: i’ve made changes in MMM-Fuel.js, node_helper.js, de.json and en.json. Now it works as it should.
              The Parameter ‘type’ in the config.js must be now an array.
              How can i send you these files, so that u can implement in the original files?
              • strawberry 3.141S
                @ostfilinchen create a pull request on github or upload the files as zip
                • O
                  ostfilinchen
                  @strawberry-3-141 i’ve open an issue on github
                  Reply Quote -1
                  • strawberry 3.141S
                    Changelog:
                    It’s now possible to show
                    • multiple fuel types at once
                    • whether the gas station is open or closed
                    Have a look on the new config options: types, sortBy and open
                    Deprecated config options: type
                    Shootout to @ostfilinchen who did the prework for it
                    alt text
                    • yawnsY
                      yawns Moderator
                      wow, nice improvement!
                      • O
                        ostfilinchen
                        Hi @strawberry-3-141,
                        can u insert the open-Parameter to the readme on github?
                        Daniel
                        • strawberry 3.141S
                          @ostfilinchen it’s done must have forgot that one
                          • F
                            FlorianRD
                            I didn’t need the “rotate Intervall”. Just sort by price (lower Price first).
                            How to modified the Settings for this result? Thanks
                            • lolobyteL
                              lolobyte
                              Hi, great job.
                              How to deactivate toggeling “rotateInterval:”
                              • O
                                ostfilinchen
                                At the Moment there’s no Option to disable the rotate-feature.
                                U can open an issue on github to ask, if he can create this option.
                                lolobyteL 1 Reply Last reply
                                • lolobyteL
                                  lolobyte @ostfilinchen
                                  @ostfilinchen Thank you, erledigt! ;-)
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @lolobyte
                                    @lolobyte done
                                    • lolobyteL
                                      lolobyte @strawberry 3.141
                                      @strawberry-3.141 thank you.
                                      Very fast reaktion.
                                      It works.
                                      • O
                                        ostfilinchen
                                        Hi @strawberry-3-141. I have an Issue with this module. My Mirror shows me no gasprice list. I wonder about it and so i check logfiles and so on. I also rebuild the string that get the request from tankerkoenig.de. The Response says: API-KEY blocked. Please contact tankerkoenig.de.
                                        On the website of tankekoenig u can download a logfile from our api-key. here i saw, that tankerkoenig get very often gets an request.
                                        [code]
                                        IP-ADDRESS - - [25/Nov/2016:06:28:21 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.008
                                        IP-ADDRESS - - [25/Nov/2016:06:29:50 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.017
                                        IP-ADDRESS - - [25/Nov/2016:06:30:07 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.009
                                        IP-ADDRESS - - [25/Nov/2016:06:31:47 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.014
                                        IP-ADDRESS - - [25/Nov/2016:06:33:08 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.012
                                        IP-ADDRESS - - [25/Nov/2016:06:34:04 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.015
                                        IP-ADDRESS - - [25/Nov/2016:06:34:36 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.011
                                        IP-ADDRESS - - [25/Nov/2016:06:34:46 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.016
                                        IP-ADDRESS - - [25/Nov/2016:06:35:06 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.013
                                        IP-ADDRESS - - [25/Nov/2016:06:36:36 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.025
                                        IP-ADDRESS - - [25/Nov/2016:06:36:50 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.009
                                        IP-ADDRESS - - [25/Nov/2016:06:37:06 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.008
                                        IP-ADDRESS - - [25/Nov/2016:06:37:37 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.011
                                        IP-ADDRESS - - [25/Nov/2016:06:39:05 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.020
                                        IP-ADDRESS - - [25/Nov/2016:06:39:18 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.021
                                        IP-ADDRESS - - [25/Nov/2016:06:39:24 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.016
                                        IP-ADDRESS - - [25/Nov/2016:06:43:21 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.013
                                        IP-ADDRESS - - [25/Nov/2016:06:44:51 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.028
                                        IP-ADDRESS - - [25/Nov/2016:06:44:51 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.032
                                        IP-ADDRESS - - [25/Nov/2016:06:45:07 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.013
                                        IP-ADDRESS - - [25/Nov/2016:06:46:47 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.016
                                        IP-ADDRESS - - [25/Nov/2016:06:48:08 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.016
                                        IP-ADDRESS - - [25/Nov/2016:06:49:04 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.011
                                        IP-ADDRESS - - [25/Nov/2016:06:49:36 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.010
                                        IP-ADDRESS - - [25/Nov/2016:06:49:47 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.017
                                        IP-ADDRESS - - [25/Nov/2016:06:50:06 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.018
                                        IP-ADDRESS - - [25/Nov/2016:06:51:36 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.027
                                        IP-ADDRESS - - [25/Nov/2016:06:51:36 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.031
                                        IP-ADDRESS - - [25/Nov/2016:06:51:53 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.011
                                        IP-ADDRESS - - [25/Nov/2016:06:52:06 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.017
                                        IP-ADDRESS - - [25/Nov/2016:06:52:36 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.017
                                        IP-ADDRESS - - [25/Nov/2016:06:54:07 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.015
                                        IP-ADDRESS - - [25/Nov/2016:06:54:18 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.014
                                        IP-ADDRESS - - [25/Nov/2016:06:54:25 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.011
                                        IP-ADDRESS - - [25/Nov/2016:06:58:21 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104 “-” “-” 0.025
                                        IP-ADDRESS - - [25/Nov/2016:06:59:50 +0100] “GET /json/list.php?lat=51.282854&lng=14.109648&rad=16&type=all&apikey=API-KEY-HERE&sort=dist HTTP/1.1” 200 104
                                        [/code]
                                        Can u please look in the code whats going wrong?
                                        Regards
                                        Daniel
                                        • strawberry 3.141S
                                          @ostfilinchen did you may test something on your mirror and restarted it every time? can you post your config part of mmm-fuel?
                                          • O
                                            ostfilinchen
                                            no, i don’t restart the mirror.
                                            here is the part of the config:
                                            	module: "MMM-Fuel",
                                            	position: "top_center",
                                            		api_key: "API-KEY",
                                            		lat: 51.282854,
                                            		lng: 14.109648,
                                            		types: ["e5","diesel"],
                                            		sortBy: "e5",
                                            		open: true,
                                            		radius: 16,
                                            		max: 3
                                            • 1 / 9
