    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 589.6k Views 48 Watching
      plumcraft
      Great idea !
        bjoern
        YES !!! Look’s good! Wow! i will test it later. Thanks !!!
          bjoern
          it works fine! Thanks a lot !!!
          • W
            WeedWood
            Perfect!!!
            • strawberry 3.141S
              After @ostfilinchen reported an issue with missing leading zeros for some postcodes, I contacted the API provider but didn’t receive any response. So i fixed it myself.
              [card:fewieden/MMM-Fuel]
              • strawberry 3.141S
                Changelog:
                Implemented voice commands to show the gas stations on a map with traffic layer
                alt text
                • O
                  ostfilinchen
                  Hi @strawberry-3-141 ,
                  is it possible, to implement an delay so that i can start this module 2 time with different sorts? Otherwise can u implement more then 1 fuel sort?
                  Regards
                  Daniel
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @ostfilinchen
                    @ostfilinchen will look into this
                    • O
                      ostfilinchen
                      @strawberry-3-141: i’ve made changes in MMM-Fuel.js, node_helper.js, de.json and en.json. Now it works as it should.
                      The Parameter ‘type’ in the config.js must be now an array.
                      How can i send you these files, so that u can implement in the original files?
                      • strawberry 3.141S
                        @ostfilinchen create a pull request on github or upload the files as zip
                        • O
                          ostfilinchen
                          @strawberry-3-141 i’ve open an issue on github
                          Reply Quote -1
                          • strawberry 3.141S
                            Changelog:
                            It’s now possible to show
                            • multiple fuel types at once
                            • whether the gas station is open or closed
                            Have a look on the new config options: types, sortBy and open
                            Deprecated config options: type
                            Shootout to @ostfilinchen who did the prework for it
                            alt text
                            • yawnsY
                              yawns Moderator
                              wow, nice improvement!
                              • O
                                ostfilinchen
                                Hi @strawberry-3-141,
                                can u insert the open-Parameter to the readme on github?
                                Daniel
                                • strawberry 3.141S
                                  @ostfilinchen it’s done must have forgot that one
                                  • F
                                    FlorianRD
                                    I didn’t need the “rotate Intervall”. Just sort by price (lower Price first).
                                    How to modified the Settings for this result? Thanks
                                    • lolobyteL
                                      lolobyte
                                      Hi, great job.
                                      How to deactivate toggeling “rotateInterval:”
                                      • O
                                        ostfilinchen
                                        At the Moment there’s no Option to disable the rotate-feature.
                                        U can open an issue on github to ask, if he can create this option.
                                        lolobyteL 1 Reply Last reply
                                        • lolobyteL
                                          lolobyte @ostfilinchen
                                          @ostfilinchen Thank you, erledigt! ;-)
                                          • strawberry 3.141S
                                            strawberry 3.141 Project Sponsor Module Developer @lolobyte
                                            @lolobyte done
                                            • 1 / 9
