Docker Container
Hey there!
I was thinking about a way to easily host MagicMirror and display the webpage on any device in the home network.
First thing that came to my mind, why not a Docker container for the Server-Only application?
Would be a really smooth way to host magicmirror on say… a homeserver, and use a rpi zero or any other network capable device to display the webpage in kiosk mode.Let me know what you think! :)
@Kukielka58 there will be docker support in the next version
@strawberry-3.141 well, that was unexpected… Good for me tho!
Thanks alot! :) -
trying to work with docker after the release of MM v.2.1.1.The documentation says to start docker with:
docker run -d \ --publish 80:8080 \ --restart always \ --volume ~/magic_mirror/config:/opt/magic_mirror/config \ --volume ~/magic_mirror/modules:/opt/magic_mirror/modules \ --name magic_mirror \ MichMich/MagicMirrorThat doesn’t work, so google helped and this is working:
docker run -d \ --publish 80:8080 \ --restart always \ --volume ~/magic_mirror/config:/opt/magic_mirror/config \ --volume ~/magic_mirror/modules:/opt/magic_mirror/modules \ --name magic_mirror \ randyramsaywack/magicmirrorNow docker ps tells me that all is running but i can’t see the site in my browser.
I tried localhost:8080 and localhost:8183, doesn’t work.The documentation says to update the config with the Docker Host IP address.
So I tried to get this with# As of Docker v1.3 you can attach to a bash shell docker exec -it 2e23d01384ac bash # That drops you into a bash shell then use the 'ip' command to grab the addr root@2e23d01384ac:/# ip add | grep global inet 172.17.0.1/16 scope global eth0but inserting this in whitelist still doesn’t work.
May someone here knows what I’m doing wrong …
Thanks,
Karsten.
Update: I found no valid mm container in the docker store.
You can build your own docker image locally with
docker build -t magic_mirror .and run it with
docker run -d --publish 8080:8080 --restart always --volume ~/magic_mirror/config:/opt/magic_mirror/config --volume ~/magic_mirror/modules:/opt/magic_mirror/modules --name magic_mirror magic_mirrorand open it in your browser with
http://localhost:8080/Be aware of this issue.
Karsten.
