    Netatmo module
    10 Posts 5 Posters 7.1k Views 4 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @zdenek
      @zdenek you have to install modules in the path ~/MagicMirror/modules as yawns mentioned, otherwise the system cant find the module
      zdenekZ 1 Reply Last reply Reply Quote 0
      • yawnsY Offline
        yawns Moderator
        Yes, my mistake, folder netatmo is correct, but it needs to be in modules
        Could you please start your mirror with npm start dev, open the console in your browser by pressing F12 and check for any errors there?
        • zdenekZ Offline
          zdenek @strawberry 3.141
          @strawberry-3.141 seems to be right. By running @yawns command I can see that there is row src=“modules/netatmo//netatmo.js”
          with error 404
          may I simply copy/paste to modules folder? Or have tu run again from github? and the command will be:
          git clone https://github.com/CFenner/MagicMirror-Netatmo-Module.git modules/netatmo
          Zdenek
          P.S.: simple copy/paste works. Thanks guys
          • K Offline
            Kai-Christoph
            @zdenek
            Hi Zdenek,
            I just installed the Netatmo-Module, but I can’t get the “refresh_token” vial Hurl-it.
            I always get an “400 Bad Request”.
            Where ist the trick?
            Maybe it’s because I don’t know what the “gant_type” “password” is supposed to be?
            Thank you for your help.
            KC
            • zdenekZ Offline
              zdenek @Kai-Christoph
              @Kai-Christoph To be honest, I´m newbie. I just followed the instructions. 1st - registered app and get appID and appSecret. Than insert URL to Hurl-It and add all mentioned parameters.
              “gant_type” - it´s I guess typo - should be ““grant_type””
              And it´s not a variable. The name of the parameter is ““grant_type”” and the Value is “password” - I guess, it´s a definition, that authentication will be done via username+password (probably there are other way - certificate? PIN? don´t know)
              BR, Zdeněk
              • K Offline
                Kai-Christoph @zdenek
                @zdenek Hihihihihi! The missing “r” was the key! Thanks for your hint!
                Cheers
                KC
                  A Former User
                  Sorry for late Reply on this old Thread, buuuut…
                  I got everything installed very quick and get it started. But its loading and loading and loading…i dont get any Information from my Netatmo Station…i started it also with “dev” and got no errors or anything else…
                  What i’ve done wrong?
                  Refresh Token? I used the Login credentials from my dev account, maybe thats my mistake?
                  Thanks for your help
                  PS: How to use moduleOrder? I dont know how to use/insert into config ;) (Newbie)
