    Two way mirror order for Europe - Orders closed!
    249 Posts 59 Posters 589.9k Views 60 Watching
    • G Offline
      Goldjunge_Chriz @Hawking
      @Hawking said in Two way mirror order in Germany - Accumulation for 2nd round:
      @Goldjunge_Chriz
      thanks for providing the pictures.
      Now I know that I will buy a mirror glas that is larger then the monitor. The follow up question is therefore: What is the largest mirror glas you can ship (within Germany). I could look up the maximum size the post allows but I don’t know how much I would have to subtract for package.
      One other question: According to the table most people order mirrors with polished edges. As far as I read they cost extra (because it is extra work). Is there any advantage if one uses a frame around the mirror (which I assume most people actually do)?
      The largest dimension the art dealer can deliver is 200x120cm. The advantages of a polished edge are that the edges are generally strengthened, the risk of injury is significantly reduced and, of course, the optical aspects. But the optical aspects are no longer visible in a framed mirror.
      • H Offline
        Hawking @Goldjunge_Chriz
        @Goldjunge_Chriz
        thanks for the quick reply. I really appreciate your work.
        I’m not sure if you understood my question regarding maximum shipment size. I meant the shipment from you to me (I can’t pick the mirror up at your place). At least at DHL the maximum size of a parcel is 1.20 m x 0.6 m x 0.6 m. From these sizes one has to subtract some (?) cm for package. On the table there are already some mirrors with “delivery” option that are larger then these sizes (e.g 1.25 x 0.7). Do you use a different company then DHL or how do you do the delivery and how much does it approximately cost?
        • G Offline
          Goldjunge_Chriz
          Yes I have an art forwarder who transport the mirror to your adress ;) For large mirrors I commissioned an art forwarder with the transport. The price is about 50 euros.
            matthiasmwolf
            Hi there,
            • Raspi available: check
            • Monitor available: check
            • Mirror available: still open
            After having found a 32" Philips TV which just needs some power supply unit-treatment to work again, the next step is to order the mirror. Please add me to the spreadsheet, @yawns
            0.9x0.6 // 0.54 // Munich // polished edges // delivery/pickup (?)
            @yakko2001, @SevenrockMirror: As the two of you plan to pick up the mirror in Schweinfurt, would it be possible to have you pick up my mirror as well and we meet in Munich once it is here? This way we can save some gas. Better for the environment as well…
            Thank you very much!
            Matthias
            • Y Offline
              yawns Moderator
              Hi Matthias, you were added to the list
                matthiasmwolf @yawns
                @yawns: Besten Dank!
                  schmo90
                  Hy i am also interessted
                  i need a mirror with the dimensions 72cm x 50cm also with polished edges.
                  I am from Upper Austria, Vöcklabruck
                  how much are the shipping costs to austria?
                  maybe we can make a sending collection with gerbin and Pegasus?
                  lg
                  • H Offline
                    @Goldjunge_Chriz said in Two way mirror order in Germany - Accumulation for 2nd round:
                    OK, I just remembered that in the first order thread there were some problems with mirrors being to large for shipment. Good to here that you found ways to ship such large mirrors.
                    What is the maximum mirror size you can ship via “regular” post (DHL, …)? Or asked differently: How many cm per size is the surrounding package? I want to avoid having to pay for the art dealer delivery just because of a few extra cm in length.
                    • G Offline
                      I will make the next order probably only with the forwarding company, so I do not have so much effort with the build of the crates. That was really a lot of work.
                      • I Offline
                        infotermoo
                        Hey @Goldjunge_Chriz, would a 1000x2000mm mirror be possible with this glass? And how about shipping cost to Estonia? Thanks for effort!
                        • H Offline
                          Please add the following order to the table:
                          Hawking // 0.369 x 1.09 // 0.40 // Munich // polished edges // delivery/pickup (?)
                          I see and understand.
                          @matthiasmwolf said in Two way mirror order in Germany - Accumulation for 2nd round:
                          I’m also living in Munich. I don’t own a car but would of course pay a share of your costs. Please write if you can pick up my mirror as well.
                          • G Offline
                            Goldjunge_Chriz @infotermoo
                            @infotermoo
                            Mirror size 2000x1000mm is possible, but delivery to Estonia is not possible…sorry
                            • I Offline
                              infotermoo
                              What about shipping to Belgium? Would that be possible?
                              • daenickD Offline
                                daenick
                                Would be possible to ship to Spain? If so, I’ll need one with this dimensions: 45cm width and 61cm height. First at all, I need the final price: mirror+shiping
                                Thanks a lot friends!
                                • G Offline
                                  @infotermoo said in Two way mirror order in Germany - Accumulation for 2nd round:
                                  Yes, Shipping to Belgium is possible ;)
                                  • G Offline
                                    Goldjunge_Chriz @daenick
                                    @daenick said in Two way mirror order in Germany - Accumulation for 2nd round:
                                    Yes shipping to Spain is possible. Please read the old thread, there you find all information about the price formation and other useful topics.
                                      jupilde
                                      Hi Chris,
                                      I would like to order a second mirror with the same size than the first one.
                                      jupilde 0.6 * 0.9 0.54 Germany, Stuttgart polished edges
                                      The first one is really great.
                                      Let’s discuss shipment once we know where the people are coming from.
                                      I could pick up some mirrors at your place and bring them to Stuttgart but shipment by DHL would be also fine for me.
                                      Best regards,
                                      Jochen
                                      G 1 Reply Last reply Reply Quote 2
                                      • Y Offline
                                        yawns Moderator
                                        Ok, I added several people.
                                        https://docs.google.com/spreadsheets/d/12fvB1R5aPwAg9_jTwEnud2PXqChdZ7VqOGfSM9tjq08/edit?usp=sharing
                                        Did I miss someone?
                                        daenickD 1 Reply Last reply Reply Quote 0
                                        • daenickD Offline
                                          daenick
                                          Wait for me!
                                          • daenickD Offline
                                            daenick @yawns
                                            @yawns 1 mirror, 0,45 and 0,61. Polished edges
                                            • 12
                                            • 13
                                            • 4 / 13
