    Scheduled restart for MM or module
    14 Posts 6 Posters 9.3k Views 6 Watching
      CyanKali
      …me again. Unfortunately, iframe reload did not work. There seems to be an known issue with refreshing pages but I tried the suggested fixes and nothing worked:
      https://github.com/TheBogueRat/MMM-iFrameReload/issues/2?_pjax=%23js-repo-pjax-container
      The author of the module does not answer me, maybe I can get some help here? When you click on the link you see my post where I describe what I already tried.
        daikaiju
        Did you ever resolve this? I’m running into the same issue.
          CyanKali
          Unfortunately no. I am still looking for a solution. And I´m still hoping somebody might help with this issue.
          D strawberry 3.141S 2 Replies Last reply Reply Quote 0
            daikaiju @CyanKali
            @CyanKali I’m not sure why the developer didn’t update the git pull for this one.
            I ran into every issue you did when trying to implement the “fix.”
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @CyanKali
              @CyanKali can you try iframe.setAttribute("timestamp", new Date().getTime()); between line 32 and 33 of the js file?
                daikaiju @strawberry 3.141
                @strawberry-3.141 This worked for me. Outstanding. Thank you.
                  CyanKali
                  Hi straawberry, thank you for your help!
                  So, my js file now looks like this:
                  	getDom: function() {
                  		var iframe = document.createElement("IFRAME");
                  		iframe.style = "border:0"
                  		iframe.width = this.config.width;
                  		iframe.height = this.config.height;
                  		iframe.scrolling = this.config.scrolling;
                  		iframe.src =  this.config.url;
                  		iframe.id = this.config.id;
                  		return iframe;
                  is that right?
                  And my congif.js now looks like this:
                  	module: 'MMM-iFrameReload',
                  	position: 'bottom_right', // This can be any of the regions.
                  		url: "http://MY_URL",
                  		width: "80%", // Optional. Default: 400px
                  		height: "400px", // Optional. Default: 800px
                  		scrolling:"no",
                  		refreshInterval: 60, //Optional. Default: 3600 = 1 hour
                  		animationSpeed: 4000,
                  Is that right?
                  The stream is working right now, but I don´t see any refresh animation. I will have to wait until tomorrow to see if it reloads because most of the times it takes some hours for the stream to freeze.
                    @CyanKali normally it should reload after 60 seconds in your case, for testing i found this site which returns every reload a random content and timestamp so you can check if it is refreshing https://www.random.org/quick-pick/?tickets=2&lottery=5x69.1x26
                      CyanKali
                      Sorry for the late reply. I updated to the new MM release and it broke everything. But now I fixed it and was able to test again.
                      I see the new content every time its refreshing, so it works!
                      Thank you so much for your help!
                      • Mitch1138M Offline
                        Mitch1138
                        I want to thank Strawberry and everyone for resolving this. I have been worrying on it for some time and this finally resolved it. Thanks for putting the full code in the example Cyankali.
