    Scheduled restart for MM or module
    14 Posts 6 Posters 10.2k Views 6 Watching
      CyanKali
      I´m in the middle of building my first MM and know next to nothing about coding. Thanks to Google I came very far, but now I´m stuck.
      Here is my problem: I want to show the stream of my foscam camera to my mirror. I tried the module “MMM-ipCam” but i could not get it to work (it always returned “undefined object”). But I am able to see the stream in a browser via URL. So I got the iframe module and now the stream is shown on my mirror, yeah.
      But: The stream freezes after a few hours. Sometimes it runs for a day and a half, sometimes for only 10 hours. After restarting the mirror, all is fine again.
      This is what I already tried:
      • I copied the “update interval” section from the compliments module and inserted it in the iframe module. I thought this would fetch the stream every few minutes and solve the problem. I don’t even now if I did it right, but it did not help.
      • I looked up cron jobs and thought maybe I could start and stop the mirror every six hours. But since I know nothing about it and I did not find the right command to quit the mirror (I know start is npm start, but what would I say to quit…?) I gave up.
      Can you help me with a few lines of code that I can insert into the module or for restarting the mirror?
      O 1 Reply Last reply
      • O
        onetwankyfive @CyanKali
        @CyanKali have you checked out MMM-iFrameReload??
          CyanKali
          Thank you so much, that was exactly what I was looking for!
          I can’t believe I did not find it with by searching, I thought I checked all the modules and forums…
          Someone added the possibility to get rid of the scrolling bars in the iframe module. I just copied the code from the iframe module and it works in the iframe reload module, too.
          I don´t want to take credit for it since I just copied it, but if it helps someone else, here is what I did:
          I added “iframe.scrolling = this.config.scrolling;” in the module file, there:
          // Override dom generator.
          getDom: function() {
          var iframe = document.createElement(“IFRAME”);
          iframe.style = “border:0”
          iframe.width = this.config.width;
          iframe.height = this.config.height;
          iframe.src = this.config.url;
          return iframe;
          After that, you can set “scrolling:“no”,” in the within the module in the config file.
          Thanks again!
            CyanKali
            …me again. Unfortunately, iframe reload did not work. There seems to be an known issue with refreshing pages but I tried the suggested fixes and nothing worked:
            https://github.com/TheBogueRat/MMM-iFrameReload/issues/2?_pjax=%23js-repo-pjax-container
            The author of the module does not answer me, maybe I can get some help here? When you click on the link you see my post where I describe what I already tried.
              daikaiju
              Did you ever resolve this? I’m running into the same issue.
                CyanKali
                Unfortunately no. I am still looking for a solution. And I´m still hoping somebody might help with this issue.
                D strawberry 3.141S 2 Replies Last reply
                  daikaiju @CyanKali
                  @CyanKali I’m not sure why the developer didn’t update the git pull for this one.
                  I ran into every issue you did when trying to implement the “fix.”
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @CyanKali
                    @CyanKali can you try iframe.setAttribute("timestamp", new Date().getTime()); between line 32 and 33 of the js file?
                    D 1 Reply Last reply
                      daikaiju @strawberry 3.141
                      @strawberry-3.141 This worked for me. Outstanding. Thank you.
                        CyanKali
                        Hi straawberry, thank you for your help!
                        So, my js file now looks like this:
                        		var iframe = document.createElement("IFRAME");
                        		iframe.style = "border:0"
                        		iframe.id = this.config.id;
                        		return iframe;
                        is that right?
                        And my congif.js now looks like this:
                        	module: 'MMM-iFrameReload',
                        	position: 'bottom_right', // This can be any of the regions.
                        		url: "http://MY_URL",
                        		width: "80%", // Optional. Default: 400px
                        		height: "400px", // Optional. Default: 800px
                        		scrolling:"no",
                        		refreshInterval: 60, //Optional. Default: 3600 = 1 hour
                        		animationSpeed: 4000,
                        Is that right?
                        The stream is working right now, but I don´t see any refresh animation. I will have to wait until tomorrow to see if it reloads because most of the times it takes some hours for the stream to freeze.
                        • strawberry 3.141S
                          @CyanKali normally it should reload after 60 seconds in your case, for testing i found this site which returns every reload a random content and timestamp so you can check if it is refreshing https://www.random.org/quick-pick/?tickets=2&lottery=5x69.1x26
                            CyanKali
                            Sorry for the late reply. I updated to the new MM release and it broke everything. But now I fixed it and was able to test again.
                            I see the new content every time its refreshing, so it works!
                            Thank you so much for your help!
                            • Mitch1138M
                              Mitch1138
                              I want to thank Strawberry and everyone for resolving this. I have been worrying on it for some time and this finally resolved it. Thanks for putting the full code in the example Cyankali.
                              • zdenekZ
                                zdenek
                                I would like to ask for help - module doesn’t work for me at all. I’ve got an error:
                                Failed to load resource: the server responded with a status of 404 (Not Found)
                                loader.js:190 Error on loading script: modules/iFrameReload//iFrameReload.js
                                but it’s not possible. here is my config.js:
                                			module: 'iFrameReload',
                                			position: 'top_center',	// This can be any of the regions.
                                					url: "http://portal.chmi.cz/files/portal/docs/meteo/rad/mobile/ra6_30min.gif",
                                					width: "160px", // Optional. Default: 400px
                                					height: "120px", // Optional. Default: 800px
                                 		       			refreshInterval: 1800  //Optional. Default: 3600 = 1 hour
                                the url exists, feel free to try. with iFrame module it works, but without updating/refresh
                                thanks for help
