    Scheduled restart for MM or module
    14 Posts 6 Posters 10.1k Views 6 Watching
    • O
      onetwankyfive @CyanKali
      @CyanKali have you checked out MMM-iFrameReload??
        CyanKali
        Thank you so much, that was exactly what I was looking for!
        I can’t believe I did not find it with by searching, I thought I checked all the modules and forums…
        Someone added the possibility to get rid of the scrolling bars in the iframe module. I just copied the code from the iframe module and it works in the iframe reload module, too.
        I don´t want to take credit for it since I just copied it, but if it helps someone else, here is what I did:
        I added “iframe.scrolling = this.config.scrolling;” in the module file, there:
        // Override dom generator.
        getDom: function() {
        var iframe = document.createElement(“IFRAME”);
        iframe.style = “border:0”
        iframe.width = this.config.width;
        iframe.height = this.config.height;
        iframe.src = this.config.url;
        return iframe;
        After that, you can set “scrolling:“no”,” in the within the module in the config file.
        Thanks again!
          CyanKali
          …me again. Unfortunately, iframe reload did not work. There seems to be an known issue with refreshing pages but I tried the suggested fixes and nothing worked:
          https://github.com/TheBogueRat/MMM-iFrameReload/issues/2?_pjax=%23js-repo-pjax-container
          The author of the module does not answer me, maybe I can get some help here? When you click on the link you see my post where I describe what I already tried.
            daikaiju
            Did you ever resolve this? I’m running into the same issue.
              CyanKali
              Unfortunately no. I am still looking for a solution. And I´m still hoping somebody might help with this issue.
              D strawberry 3.141S 2 Replies Last reply Reply Quote 0
                daikaiju @CyanKali
                @CyanKali I’m not sure why the developer didn’t update the git pull for this one.
                I ran into every issue you did when trying to implement the “fix.”
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @CyanKali
                  @CyanKali can you try iframe.setAttribute("timestamp", new Date().getTime()); between line 32 and 33 of the js file?
                    daikaiju @strawberry 3.141
                    @strawberry-3.141 This worked for me. Outstanding. Thank you.
                      CyanKali
                      Hi straawberry, thank you for your help!
                      So, my js file now looks like this:
                      		var iframe = document.createElement("IFRAME");
                      		iframe.style = "border:0"
                      		iframe.id = this.config.id;
                      		return iframe;
                      is that right?
                      And my congif.js now looks like this:
                      	module: 'MMM-iFrameReload',
                      	position: 'bottom_right', // This can be any of the regions.
                      		url: "http://MY_URL",
                      		width: "80%", // Optional. Default: 400px
                      		height: "400px", // Optional. Default: 800px
                      		scrolling:"no",
                      		refreshInterval: 60, //Optional. Default: 3600 = 1 hour
                      		animationSpeed: 4000,
                      Is that right?
                      The stream is working right now, but I don´t see any refresh animation. I will have to wait until tomorrow to see if it reloads because most of the times it takes some hours for the stream to freeze.
                      • strawberry 3.141S
                        @CyanKali normally it should reload after 60 seconds in your case, for testing i found this site which returns every reload a random content and timestamp so you can check if it is refreshing https://www.random.org/quick-pick/?tickets=2&lottery=5x69.1x26
                          CyanKali
                          Sorry for the late reply. I updated to the new MM release and it broke everything. But now I fixed it and was able to test again.
                          I see the new content every time its refreshing, so it works!
                          Thank you so much for your help!
                          • Mitch1138M
                            Mitch1138
                            I want to thank Strawberry and everyone for resolving this. I have been worrying on it for some time and this finally resolved it. Thanks for putting the full code in the example Cyankali.
                            • zdenekZ
                              zdenek
                              I would like to ask for help - module doesn’t work for me at all. I’ve got an error:
                              Failed to load resource: the server responded with a status of 404 (Not Found)
                              loader.js:190 Error on loading script: modules/iFrameReload//iFrameReload.js
                              but it’s not possible. here is my config.js:
                              			module: 'iFrameReload',
                              			position: 'top_center',	// This can be any of the regions.
                              					url: "http://portal.chmi.cz/files/portal/docs/meteo/rad/mobile/ra6_30min.gif",
                              					width: "160px", // Optional. Default: 400px
                              					height: "120px", // Optional. Default: 800px
                               		       			refreshInterval: 1800  //Optional. Default: 3600 = 1 hour
                              the url exists, feel free to try. with iFrame module it works, but without updating/refresh
                              thanks for help
