    v2.1.1 Update Error
    13 Posts 6 Posters 8.9k Views 6 Watching
    • lucallmonL
      lucallmon
      Tried to run the update and this is what I got:
      pi@raspberrypi:~ $ cd MagicMirror
      pi@raspberrypi:~/MagicMirror $ git pull && npm install
      Updating 8010e62..1a2b4f8
      error: Your local changes to the following files would be overwritten by merge:
      	modules/default/clock/clock.js
      	modules/default/compliments/compliments.js
      Please, commit your changes or stash them before you can merge.
      Aborting
      It completely aborts. Not sure what to do.
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @lucallmon
        @lucallmon this is because you changed those mentioned files manually. If you want to revert your changes permamently do git checkout modules/default/clock/clock.js modules/default/compliments/compliments.js and rerun your command
        B lucallmonL 2 Replies Last reply
        • O
          ostfilinchen
          Hi all,
          I get an error during loading says m.loaded is not a function. Is there an workaround?
          Regards
          Daniel
          • O
            ostfilinchen
            Hi all,
            i found the module that gives me the error. It’s the MMM-PIR-Sensor module. The error says, that electron has the wrong abi-version: Expected 49, got 53.
            What can i do to fix it? I have remove the node_modules Folder in MM\modules\MMM-PIR-Sensor and install it again. But the error is still the same.
            Daniel
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @ostfilinchen
              @ostfilinchen you have to rebuild like @yawns mentioned here https://forum.magicmirror.builders/topic/948/error-found-error-module-version-mismatch-expected-50-got-46
                bluecaka69 @strawberry 3.141
                @strawberry-3.141 said in v2.1.1 Update Error:
                I got this for compliments as well if info what you mentioned will it keep everything the same?? I had a heck of a time getting it to work I don’t want to loose anything
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @bluecaka69
                  @bluecaka69 with my command you will loose your changes you can copy the files to a backup directory first
                  B 1 Reply Last reply
                    @strawberry-3.141 so just make a copy of the config file. Run your command, then git pull && npm install. The transfer over my saved config??
                    strawberry 3.141S yawnsY 2 Replies Last reply
                    • strawberry 3.141S
                      @bluecaka69 no those files which get complaint about modifications but you can save your config as well
                      • yawnsY
                        yawns Moderator @bluecaka69
                        @bluecaka69
                        No, not the config file. You changed things in clock.js and compliments.js and therefore git pull cannot update these files to be exactly like the updates ones in the repository.
                        lucallmonL 1 Reply Last reply
                        • lucallmonL
                          lucallmon @yawns
                          @yawns so what do I do to get rid of the error then?
                          mochmanM 1 Reply Last reply
                          • mochmanM
                            mochman Module Developer @lucallmon
                            @lucallmon If you don’t care about the changes you made to those files then you can run
                            git stash from your MagicMirror directory. You should be able to run the git pull command after that.
                            If you want to keep them, I’d just copy those files to somewhere not in your MagicMirror directory, run the stash command, pull the new MM, and put them back if you think they aren’t going to break anything in 2.1.1
                            • lucallmonL
                              lucallmon @strawberry 3.141
                              @strawberry-3.141 this worked! Thanks!
