After upgrade (v2.1.1) multiple calendars not displaying
6 Posts 4 Posters 3.5k Views 7 Watching
    Mitch1138
    I have two calendars which would display fine before the update. After the update only the 2nd calendar displays. Has anyone else seen this?
    Thanks, Dave
    module: ‘calendar’,
    header: ‘Calendar’,
    position: ‘top_left’,
    colored: true,
    url: ‘https://calendar.google.com/calendar/ical/.../basic.ics’,
    color: ‘#f70000’
                       	 url: 'https://calendar.google.com/calendar/ical/.../basic.ics',
                	color: '#04f448'
    • Y Offline
      yoda16
      I am having the same issue after upgrading.
      • Y Offline
        yoda16
        It doesn’t look like it has anything to do with the position of the calendar. If i switch the calendar positions it follows the calendar not the placement.
          Chadeus
          I have the same issue with Google Calendar private url. I have two calendars running, a private url and a public url. The private url is not working but the public url DOES work strangely enough. I have two pi’s, one updated and one not. The pi that has not been updated still has that private url and it works, but the post update does not.
            Mitch1138
            Just for info, after upgrading to v2.2.0, this issue resurfaced. I tried replacing the ical scripts as described here: https://github.com/MichMich/MagicMirror/issues/839#issuecomment-298308733
            but that didn’t work for me. I used this recommendation which was posted on the forum and was overwritten when I updgraded:
            Edit this file:
            /home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js
            • Go to line 56 or search for the first occurance of “ORDINAL_BASE” and change this line:
              ORDINAL_BASE: new Date(1970, 0, 1), ORDINAL_BASE: new Date(1000, 0, 1), (set it to a lower year like 1900, I used 1000)
            • Then restart your magic mirror
            L 1 Reply Last reply Jan 21, 2018, 7:50 PM Reply Quote 4
            • L Offline
              lavolp3 Module Developer @Mitch1138
              @Mitch1138 said in After upgrade (v2.1.1) multiple calendars not displaying:
              Edit this file:
              This resolved the same problem for me. Thanks!
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
