    Autostart Issue and No Interface
    7 Posts 3 Posters 3.3k Views 3 Watching
    • hartattackH Offline
      hartattack
      Did you install the latest version of node.js?
      • G Offline
        gshimself
        • G Offline
          gshimself
          Hi. Can you do
          sudo cat /home/pi/MagicMirror/npm-debug.log
          and post some of that code?
            dapandam @hartattack
            @hartattack yes I have, I even launched the automatic installation couple times to be sure.
            Minimum Node version: v5.1.0
            Installed Node version: v6.10.2
            No Node.js upgrade nessecery.
            It seems like MagicMirror is already installed.
            To prevent overwriting, the installer will be aborted.
            Please rename the ~/MagicMirror folder and try again.
            @gshimself thanks for your help, here is the code i got from the debug log
            1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
            2 info using npm@3.10.10
            3 info using node@v6.10.2
            5 info lifecycle magicmirror@2.1.1~prestart: magicmirror@2.1.1
            6 silly lifecycle magicmirror@2.1.1~prestart: no script for prestart, continuing
            7 info lifecycle magicmirror@2.1.1~start: magicmirror@2.1.1
            8 verbose lifecycle magicmirror@2.1.1~start: unsafe-perm in lifecycle true
            9 verbose lifecycle magicmirror@2.1.1~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
            10 verbose lifecycle magicmirror@2.1.1~start: CWD: /home/pi/MagicMirror
            11 silly lifecycle magicmirror@2.1.1~start: Args: [ '-c', 'sh run-start.sh' ]
            12 silly lifecycle magicmirror@2.1.1~start: Returned: code: 1  signal: null
            13 info lifecycle magicmirror@2.1.1~start: Failed to exec start script
            14 verbose stack Error: magicmirror@2.1.1 start: `sh run-start.sh`
            14 verbose stack Exit status 1
            14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
            14 verbose stack     at emitTwo (events.js:106:13)
            14 verbose stack     at EventEmitter.emit (events.js:191:7)
            14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
            14 verbose stack     at ChildProcess.emit (events.js:191:7)
            14 verbose stack     at maybeClose (internal/child_process.js:886:16)
            14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
            15 verbose pkgid magicmirror@2.1.1
            16 verbose cwd /home/pi/MagicMirror
            17 error Linux 4.4.50-v7+
            18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
            19 error node v6.10.2
            20 error npm  v3.10.10
            21 error code ELIFECYCLE
            22 error magicmirror@2.1.1 start: `sh run-start.sh`
            22 error Exit status 1
            23 error Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
            23 error Make sure you have the latest version of node.js and npm installed.
            23 error If you do, this is most likely a problem with the magicmirror package,
            23 error not with npm itself.
            23 error Tell the author that this fails on your system:
            23 error     sh run-start.sh
            23 error You can get information on how to open an issue for this project with:
            23 error     npm bugs magicmirror
            23 error Or if that isn't available, you can get their info via:
            23 error     npm owner ls magicmirror
            23 error There is likely additional logging output above.
            24 verbose exit [ 1, true ]
              dapandam
              npm WARN prefer global coffee-script@1.10.0 should be installed with -g
              npm WARN prefer global jsonlint@1.6.2 should be installed with -g
              npm WARN prefer global colorguard@1.2.0 should be installed with -g
              I have also this code showing up when I want to install MagicMirror, thoughts ?
                dapandam
                I think I found the problem ! It was a problem with Electron. I followed some advice giving in this thread: https://github.com/MichMich/MagicMirror/issues/145
                “running “sudo npm install electron” (after the error message) in the terminal on the gui it worked starting in the terminal on the gui.”
