    MMM-Formula1 - Formula 1 Standings
    30 Posts 10 Posters 22.0k Views 8 Watching
      Mar
      This module currently only says loading for drivers and constructors. Is this because the season hasnt started yet?
      Is there a way to perhaps put a message/deactivate the module or something there if the season hasnt started?
      • I Offline
        ianperrin @Mar
        @Mar - Unfortunately we are in the hands of the API provider as to when the 2017 data is considered ‘current’.
        The work around is to make sure you have the latest version of the module then temporarily set the season option to ‘2017’, e.g.
                    module: 'MMM-Formula1',
                    position: 'top_right',
                    header: 'F1 Standings',
                        season: '2017'
        "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
          Mar @ianperrin
          @ianperrin thank you for that, i was also more just curious that i didn’t implement it incorrectly. This is a workaround i can live with.
          Thank you.
          • W Offline
            wizz
            • W Offline
              wizz
              @ianperrin I got a problem as in this below picture you see that the Driver and the constructor is separated but for me it is sitting together like this DriverConstructor.
              Also the F1 Race Schedule and the F1 Driver Standings is on the right hand side and not as in the picture. Any one know a solution?
              alt text
              • W Offline
                wizz
                @wizz said in MMM-Formula1 - Formula 1 Standings:
                @ianperrin
                @ianperrin or some one have an solution?
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @wizz
                  @wizz i guess you have the modules on the right side of your mirror thats most likely why your text is aligned right. you can change that by adding the class align-left to the config or add a css rule in custom.css to do so.
                  to add some spacing to the table you could add something like
                  .MMM-Formula1 table {
                      border-spacing: 10px 0;
                      border-collapse: separate;
                  to your custom.css
                  W 2 Replies Last reply Reply Quote 1
                  • W Offline
                    wizz @strawberry 3.141
                    @strawberry-3.141 thanks will try tonight :)
                    • W Offline
                      @strawberry-3.141 Well some improvments but still some issues. will try to fix that in the best way.
                        @wizz a screenshot of your ui would be great
