    MMM-Formula1 - Formula 1 Standings
    30 Posts 10 Posters 23.1k Views 8 Watching
      Mar @ianperrin
      @ianperrin thank you for that, i was also more just curious that i didn’t implement it incorrectly. This is a workaround i can live with.
      Thank you.
      • W Offline
        wizz
        • W Offline
          wizz
          @ianperrin I got a problem as in this below picture you see that the Driver and the constructor is separated but for me it is sitting together like this DriverConstructor.
          Also the F1 Race Schedule and the F1 Driver Standings is on the right hand side and not as in the picture. Any one know a solution?
          alt text
          • W Offline
            wizz
            @wizz said in MMM-Formula1 - Formula 1 Standings:
            @ianperrin
            @ianperrin or some one have an solution?
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @wizz
              @wizz i guess you have the modules on the right side of your mirror thats most likely why your text is aligned right. you can change that by adding the class align-left to the config or add a css rule in custom.css to do so.
              to add some spacing to the table you could add something like
              .MMM-Formula1 table {
                  border-spacing: 10px 0;
                  border-collapse: separate;
              to your custom.css
              W 2 Replies Last reply Reply Quote 1
              • W Offline
                wizz @strawberry 3.141
                @strawberry-3.141 thanks will try tonight :)
                • W Offline
                  @strawberry-3.141 Well some improvments but still some issues. will try to fix that in the best way.
                    @wizz a screenshot of your ui would be great
                      Mar
                      I’m still not able to show two modules, one for drivers and one for constructors. When i disable one module the other works…but when i try to use both only the first one works?? How are people showing both?
                                              module: 'MMM-Formula1',
                                              //disabled: true,
                                              classes: 'PAGE2',
                                              position: 'top_right',
                                              header: 'F1 Driver Standings',
                                                      maxRows: 12
                                              //disabled: true,
                                              classes: 'PAGE2',
                                              header: 'F1 Constructor Standings',
                                                      type: 'CONSTRUCTOR'
                        Peter
                        Did anyone find the 2018 season Formula 1 ICS?
                        Peter
                          strawberry 3.141 Project Sponsor Module Developer @Peter
                          @Peter from what i can see in the code is, that the module generates its own ics and doesn’t use a 3rd party ics. The data it uses therefore seems to be already updated, so by changing the season in config to 2018 you should be fine. season: 2018 or you wait until the default value 'current' gets changed automatically to 2018 here http://ergast.com/api/f1/current
                            Peter @strawberry 3.141
                            @strawberry-3.141 it works now (season set to 2018).
                            But as soon as I try to change the flag-checkered color in my custom css the calendar entries for Formula 1 are gone.
                            Any advice?
                            Peter
                              @Peter what did you put in custom css
                                @strawberry-3.141 solved!
                                There was an extra space in my config file just before flag-checkered.
                                Thanks for your help!
                                Peter
                                • F Offline
                                  fabbr
                                  I can’t make the Calendar work … what am I doing wrong?
                                  -Also, any way to have the formulaE? I saw that it uses almost the same API: https://ergast.com/mrd/formula-e-series-support/
                                  Thanks !
                                  		            header: 'F1 Standings',
                                  				   //calendar: 'true',
                                  				    grayscale: false,
                                  				    season: 2018,
                                  				    showFooter: true,
                                  				    calendar: true,
                                  				    maxRows: 7
                                  				                // Optional configuration options - see https://github.com/ianperrin/MMM-Formula1#configuration-options
                                  			header: "F1-Schedule",
                                  					//	maximumEntries: 4,
                                  					//	symbol: "calendar-check-o ",
                                  					//	url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                                  						symbol: 'flag-checkered',
                                  						url: 'http://localhost:8080/MMM-Formula1/schedule.ics'
                                    Peter
                                    Does anybody see the new 2018 standings after yesterdays races?
                                    I don’t and I even don’t see the next races in my calendar any more.
                                    Peter
                                    • F Offline
                                      fabbr @Peter
                                      @Peter Hey Peter, I just checked and mine is working ok and showing today’s results.
                                      If yours are still not showing anything, send us your config code of this module and we can try to help you out
                                        Peter @fabbr
                                        Problem solved: localhost 8080 was in use with another module I was experimenting with.
                                        It works fine now.
                                        Thanks!
                                        Peter@fabbr
                                        I 1 Reply Last reply Reply Quote 1
                                        • I Offline
                                          ianperrin @Peter
                                          @Peter it’s worth noting that the API isn’t immediately updated following each race so hang in there, the data usually updates by the end of the same day of the race
                                          "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
                                            Peter
                                            I am missing the country flag of Charles Leclerc (Monaco).
                                            Can somebody give me a hint how to fix this?
                                            Peter
