    Total Noob - Successful Install on a Pi 3 B - How do I open it?
    13 Posts 2 Posters 5.9k Views 2 Watching
      Mykle1 Project Sponsor Module Developer @orangeclover1
      @orangeclover1
      Hiding of the mouse was part of the install directions but a black screen with no message “Create a config?”
      • O Offline
        orangeclover1
        Another mini update - its now accessible on other computers on my network (going to localhost:8080) just still sitting with a black screen on my pi
          Mykle1 Project Sponsor Module Developer @Mykle1
          @Mykle1
          Yes, it would, if the mirror is black, then going to it using a browser will only see black as well
            @orangeclover1
            can you get to the terminal and post any errors here. Copy them and paste them in here
            • O Offline
              orangeclover1
              Yep I have a mouse and… nothing else. I dont have a create a config message - just a blank black screen and full mouse clickability? just checked the terminal thanks to task manager and it looks like there arent any errors
                @orangeclover1 said in Total Noob - Successful Install on a Pi 3 B - How do I open it?:
                Scroll back to the info in the terminal till you see the npm start command you made to run the mirror. Copy everything after that and paste here
                  @orangeclover1
                  Put a tick before you paste it and at the end of the paste. The tick is your TILDE key (without shift)
                  • O Offline
                    orangeclover1
                    magicmirror@2.1.1 start /home/pi/MagicMirror
                    sh run-start.sh
                    Starting MagicMirror: v2.1.1
                    Loading config …
                    Loading module helpers …
                    All module helpers loaded.
                    Starting server on port 8080 …
                    Starting server op port 8080 …
                    You’re using a full whitelist configuration to allow for all IPs
                    Server started …
                    Starting module: newsfeed
                    Sockets connected & modules started …
                    Launching application.
                    Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                    Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
                    • O Offline
                      orangeclover1
                      for future people who stumble here:
                      “npm start” was what I was missing to get things started up
                      I had a weird black electron pop up - realized it was a config file issue - for mine it ended up being a random address in the “address” section above the ipwhite list.
                      Thanks to Mykle for the help!
