    Total Noob - Successful Install on a Pi 3 B - How do I open it?
    13 Posts 2 Posters 6.4k Views 2 Watching
      Mykle1 Project Sponsor Module Developer @orangeclover1
      @orangeclover1 said in Total Noob - Successful Install on a Pi 3 B - How do I open it?:
      :8000
      The port is :8080
      • O Offline
        orangeclover1
        Thank you!!! I just ran the npm start - and it looks like …something… happened? I now have a large blank empty black screen (mouse still usable and I can get to task manager) so … maybe its trying to work?
          @orangeclover1
          Hiding of the mouse was part of the install directions but a black screen with no message “Create a config?”
          • O Offline
            orangeclover1
            Another mini update - its now accessible on other computers on my network (going to localhost:8080) just still sitting with a black screen on my pi
              Mykle1 Project Sponsor Module Developer @Mykle1
              @Mykle1
              Yes, it would, if the mirror is black, then going to it using a browser will only see black as well
                @orangeclover1
                can you get to the terminal and post any errors here. Copy them and paste them in here
                • O Offline
                  orangeclover1
                  Yep I have a mouse and… nothing else. I dont have a create a config message - just a blank black screen and full mouse clickability? just checked the terminal thanks to task manager and it looks like there arent any errors
                    Scroll back to the info in the terminal till you see the npm start command you made to run the mirror. Copy everything after that and paste here
                      @orangeclover1
                      Put a tick before you paste it and at the end of the paste. The tick is your TILDE key (without shift)
                      • O Offline
                        orangeclover1
                        magicmirror@2.1.1 start /home/pi/MagicMirror
                        sh run-start.sh
                        Starting MagicMirror: v2.1.1
                        Loading config …
                        Loading module helpers …
                        All module helpers loaded.
                        Starting server on port 8080 …
                        Starting server op port 8080 …
                        You’re using a full whitelist configuration to allow for all IPs
                        Server started …
                        Starting module: newsfeed
                        Sockets connected & modules started …
                        Launching application.
                        Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                        Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                        Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
                        • O Offline
                          orangeclover1
                          for future people who stumble here:
                          “npm start” was what I was missing to get things started up
                          I had a weird black electron pop up - realized it was a config file issue - for mine it ended up being a random address in the “address” section above the ipwhite list.
                          Thanks to Mykle for the help!
