    http request
    53 Posts 7 Posters 53.7k Views 6 Watching
    • E
      Eunanibus Module Developer
      Having good success. Can I get an example of the XML you’re trying to display?
      • E
        Well, I’ve spent the last couple of evenings trying to build something for you. You can download it here.
        Give it a try and let me know how it does for you.
        • A
          acdacd2
          I will test it today.
          Simple of the xml file
          <response>
          <led0>0</led0>
          <led1>0</led1>
          <led2>0</led2>
          <led3>0</led3>
          <led4>1</led4>
          <led5>0</led5>
          <led6>0</led6>
          <led7>0</led7>
          <led8>0</led8>
          <led9>0</led9>
          <led10>0</led10>
          <led11>0</led11>
          <led12>0</led12>
          <led13>0</led13>
          <led14>0</led14>
          <led15>0</led15>
          <led16>0</led16>
          <led17>0</led17>
          <led18>0</led18>
          <led19>0</led19>
          <led20>0</led20>
          <led21>0</led21>
          <led22>0</led22>
          <led23>0</led23>
          <led24>0</led24>
          <led25>0</led25>
          <led26>0</led26>
          <led27>0</led27>
          <led28>0</led28>
          <led29>0</led29>
          <led30>0</led30>
          <led31>0</led31>
          <btn0>up</btn0>
          <btn1>up</btn1>
          <btn2>up</btn2>
          <btn3>up</btn3>
          <btn4>up</btn4>
          <btn5>up</btn5>
          <btn6>up</btn6>
          <btn7>up</btn7>
          <btn8>up</btn8>
          <btn9>up</btn9>
          <btn10>up</btn10>
          <btn11>up</btn11>
          <btn12>up</btn12>
          <btn13>up</btn13>
          <btn14>up</btn14>
          <btn15>up</btn15>
          <btn16>up</btn16>
          <btn17>up</btn17>
          <btn18>up</btn18>
          <btn19>up</btn19>
          <btn20>up</btn20>
          <btn21>up</btn21>
          <btn22>up</btn22>
          <btn23>up</btn23>
          <btn24>up</btn24>
          <btn25>up</btn25>
          <btn26>up</btn26>
          <btn27>up</btn27>
          <btn28>up</btn28>
          <btn29>up</btn29>
          <btn30>up</btn30>
          <btn31>up</btn31>
          <day>24/06/2016</day>
          <time0>08:55:17</time0>
          <analog0>22</analog0>
          <analog1>746</analog1>
          <analog2>749</analog2>
          <analog3>215</analog3>
          <analog4>0</analog4>
          <analog5>0</analog5>
          <analog6>0</analog6>
          <analog7>0</analog7>
          <analog8>0</analog8>
          <analog9>0</analog9>
          <analog10>0</analog10>
          <analog11>0</analog11>
          <analog12>0</analog12>
          <analog13>0</analog13>
          <analog14>0</analog14>
          <analog15>0</analog15>
          <count0>22</count0>
          <count1>0</count1>
          <count2>0</count2>
          <count3>0</count3>
          <count4>0</count4>
          <count5>0</count5>
          <count6>0</count6>
          <count7>0</count7>
          <tinfo>---</tinfo>
          <version>3.05.38_vsr</version>
          </response>
          • E
            Cool. It should work fine! Hurry up and try it, I made it for you :laughing:
            More information about it is here - I posted it for everyone to download.
            • A
              acdacd2
              some errors with nom install
              pi@raspberrypi:~/MagicMirror/modules/default/MMM-HTTPRequestDisplay $ npm install
              npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
              npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/node_modules/node_helper/package.json’
              npm WARN modules No description
              npm WARN modules No repository field.
              npm WARN modules No README data
              npm WARN modules No license field.
              P 1 Reply Last reply
              • K
                KirAsh4 Moderator
                You shouldn’t need to run 'npm install' inside the module folder unless the author specifically told you to do that.
                • A
                  acdacd2
                  I did that,
                  Now it’s solved, I copied the .json in the right folder
                  • E
                    Awesome. @KirAsh4 is correct - The README has all the instructions so be sure to take a look.
                    Please let me know how it works cause you’ll be the first person to use it
                    • K
                      KirAsh4 Moderator
                      As a further explanation, 'npm install' is only required if the module you are installing requires other node modules to also be installed. When you first install MagicMirror you have to run 'npm install' to install all the dependencies for it to work, however generally, modules don’t need that. The exception is if someone writes a module that requires another node module that isn’t already installed. So there was no need to run that, nor to copy any '.json' package files anywhere.
                      • A
                        acdacd2
                        is that correct ?
                        		module: 'MMM-HTTPRequestDisplay',
                        		position: 'bottom_bar',	// This can be any of the regions. Best results in left or right regions.
                        		header: 'MMM-HTTPRequestDisplay', // This is optional
                        			accessToken: 'http://api.openweathermap.org/data/2.5/weather?q=London,uk&mode=xml',
                        Note from Moderator: Please use Markdown on code snippets for easier reading.
                        • E
                          Sorry, I made a lot of mistakes on the README it seems.
                          Instead of
                          accessToken : "http://etc"
                          use
                          httpRequestURL: "http://etc"
                          apologies
                          • A
                            acdacd2
                            no problemo,
                            with this config, black screen
                            			httpRequestURL: 'http://192.168.1.248:8889/status.xml',
                            • E
                              Make sure that you’re not just copy and pasting blindly into your config file.
                              After each
                              etc
                              Note the comma , after the module. That comma should only be there if there are more modules.
                              Likewise, if you’re pasting it last, you need to make sure the module before it has one, to let the script know there are more modules after the previous one.
                              So the pattern is
                                 module: ‘firstModule’,
                                 option : ""
                              }, <<< COMMA HERE
                                 module: ‘middleModule’,
                                 option : ""
                              }, <<< COMMA HERE
                                 module: ‘last module’,
                                 option : ""
                              } <<<<< NO COMMA
                              hope that makes sense. hopefully that’s the problem.
                              • A
                                acdacd2
                                • A
                                  acdacd2
                                  • E
                                    Can you Zip up and upload your config file somewhere I can download it and I’ll take a look? Somewhere like pastebin.
                                    • K
                                      KirAsh4 Moderator
                                      Hey @acdacd2, please use proper Markdown when posting code. It really isn’t that hard to do and it makes it so much easier and pleasant for others to read, and possibly find errors quicker. Specifically you need to use back ticks before and after your code:
                                           like so. Note that a back tick is not the same as the normal apostrophe, ` versus ' .
                                      • E
                                        @KirAsh4 can you confirm MM startup with my module with this config file?
                                        The module won’t show any results but MM should boot?
                                        • K
                                          KirAsh4 Moderator
                                          The file ‘status.xml’ doesn’t exist on my system, so it gets a 404 returned, however it does load up, and it does work.
                                          • A
                                            acdacd2
                                            I have the same message with my environment.
                                            In a browse it’s ok
                                            • 2 / 3
