Solved [ORDER CLOSED] Two way mirror order in Germany
@Advokaten
Thank you very much for the kind offer. But having had a good sleep or two over the issue I managed to find peace with myself again ;-) All in all it’s just a broken mirror…
I did order a second mirror along with the first and decided to simply change my plans for its use. I went to my local glass shop and asked them to cut it in half. That way I will end up with 2 mirrors. Ok, they are different in size now, but hey? I will end up with 2 mirrors still :)Again, I really do appreciate your offer as it proves a hell of a lot in regards of community spirit. Especially since it is not the fault of any of you. I do hope though that you do not bother that I have to turn down your offer. Everything is fine.
Thanks for the pictures.
@lolobyte said in [ORDER CLOSED] Two way mirror order in Germany:
Here is my Cam picture behind the mirror from @Goldjunge_Chriz.
What do you mean by “old mirror glass” and “new mirror glass”? Anyway, both pictures look very good, I hope that even gesture detection trough the glass should be possible. Can you also provide details how you attached the raspi-camera (regular or also noir variant?) at the back of the mirror?
like @Goldjunge_Chriz said and i mentioned, the new mirror glass is the one from @Goldjunge_Chriz .
My setup is like this.
@lolobyte, and the front/side?? Thanks!
is the mirror???
@Advokaten maybe this will help you!
Hi together,
long weekend - perfect to finish the mirror hardware.
Please find attached some pictures of the assembly + first impressions of the running mirror.
(due to i still struggling to bring my java software to the raspberry, there are some cables to the laptop who will disappear in the final setup).Overall I´m satisfied, I believe I need to play a little bit with the light conditions and install a spot on top of the mirror to compensate the light absorbation of the mirror.
Might it be possible to craft a glass working like a “silver reflected sun-glass”?
Hi @mantha , great to see your mirror goal without any broken corners. ;-)
Nice work. Great idea with your AL-Rail.
What kind of modules you are using? Standard?
I don’t think so! -
No it is a own development! The objective of the project was to get in touch with advanced AI and IoT.
I struggled to get this working with Node.js and python. So I failed back to Java with a Javafx frontend. -
hey look awesome ! Are you willing to share that with the community?
