    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 3.0m Views 60 Watching
    • T
      tomster @Advokaten
      @Advokaten
      Thank you very much for the kind offer. But having had a good sleep or two over the issue I managed to find peace with myself again ;-) All in all it’s just a broken mirror…
      I did order a second mirror along with the first and decided to simply change my plans for its use. I went to my local glass shop and asked them to cut it in half. That way I will end up with 2 mirrors. Ok, they are different in size now, but hey? I will end up with 2 mirrors still :)
      Again, I really do appreciate your offer as it proves a hell of a lot in regards of community spirit. Especially since it is not the fault of any of you. I do hope though that you do not bother that I have to turn down your offer. Everything is fine.
      • H
        Hawking @lolobyte
        Thanks for the pictures.
        @lolobyte said in [ORDER CLOSED] Two way mirror order in Germany:
        @Hawking
        Here is my Cam picture behind the mirror from @Goldjunge_Chriz.
        What do you mean by “old mirror glass” and “new mirror glass”? Anyway, both pictures look very good, I hope that even gesture detection trough the glass should be possible. Can you also provide details how you attached the raspi-camera (regular or also noir variant?) at the back of the mirror?
        • L
          lolobyte @Hawking
          @Hawking
          like @Goldjunge_Chriz said and i mentioned, the new mirror glass is the one from @Goldjunge_Chriz .
          My setup is like this.
          • A
            Advokaten @lolobyte
            @lolobyte, and the front/side?? Thanks!
            • L
              lolobyte
              is the mirror???
              • L
                lolobyte @Advokaten
                @Advokaten maybe this will help you!
                  mantha
                  Hi together,
                  long weekend - perfect to finish the mirror hardware.
                  Please find attached some pictures of the assembly + first impressions of the running mirror.
                  (due to i still struggling to bring my java software to the raspberry, there are some cables to the laptop who will disappear in the final setup).
                  Overall I´m satisfied, I believe I need to play a little bit with the light conditions and install a spot on top of the mirror to compensate the light absorbation of the mirror.
                  Might it be possible to craft a glass working like a “silver reflected sun-glass”?
                  ? A 2 Replies Last reply Reply Quote 1
                  • L
                    lolobyte
                    Hi @mantha , great to see your mirror goal without any broken corners. ;-)
                    Nice work. Great idea with your AL-Rail.
                    What kind of modules you are using? Standard?
                    I don’t think so!
                      mantha
                      No it is a own development! The objective of the project was to get in touch with advanced AI and IoT.
                      I struggled to get this working with Node.js and python. So I failed back to Java with a Javafx frontend.
                        Binog
                        hey look awesome ! Are you willing to share that with the community?
                          mantha @Binog
                          @Binog sure, once when it is finished. Currently there are some “workarounds” like hard coded login to mercedes connect.me for controlling the auxheat what prevent me from sharing…
                          JerryPJ 1 Reply Last reply Reply Quote 0
                            sero @mantha
                            @mantha
                            The image of the car interieur is from the Mercedes Connect Me webapp, isn’t it? 👍 Did you manage to show/control the auxheat from your mirror?
                              A Former User @mantha
                              @mantha Nice work! Can you please post a picture from the rear side?
                              • W
                                Woody
                                Hi all you DIYer !
                                got my mirror finished this weekend and just want to show you the result. Unfortunately, the mirrorglas itself is not what I’ve expected, in particuler under my light conditions it’s to dark. Maybe I’ll replace it in the future. Anyway this should not come over as criticism, @Goldjunge_Chriz made a great job and and I want to say thanks again.0_1492519591578_Pic001.jpg 0_1492519807695_Pic002.jpg 0_1492519832547_Pic003.jpg
                                A 1 Reply Last reply Reply Quote 1
                                • A
                                  Advokaten @Woody
                                  @Woody what happens if you add a light source above or in front of the mirror? Does it seem “clearer”??
                                  • A
                                    Advokaten @mantha
                                    @mantha I love the design you made with the frame. Any possibility of revealing where you found the materials (particularly the aluminum)? Also, what size is the mirror and monitor? :) Thanks
                                    • W
                                      Woody
                                      @Advokaten Yes, I tried several light scenarios with different but not satisfying results.
                                        A Former User @Woody
                                        @Woody Are you happy with your mirror choice?
                                        • A
                                          Ali Baba
                                          With which glue can i fix the mirror at a wodden plate? I try it at weekend with mirror Mounting Tape from Tesa at the edges of the mirror but some hours later the mirror
                                          Dissolved itself. The other problem is that the tape is white and so i can see it Through the mirror.
                                          At next i will try “tesa doppelseitiges Montageband Powerbond”. This is black and so i hope that it would be nott seen through the mirror.
                                            A Former User @Ali Baba
                                            @Ali-Baba Realy nice idea and work. Instead of glue or tapes you can use a alu u-strip screwed to the wodden plate. So you can remove the mirror easier in the future.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 28 / 28
