    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 2.9m Views 60 Watching
      Advokaten @lolobyte
      @lolobyte, and the front/side?? Thanks!
      • L Offline
        lolobyte
        is the mirror???
        • L Offline
          lolobyte @Advokaten
          @Advokaten maybe this will help you!
            mantha
            Hi together,
            long weekend - perfect to finish the mirror hardware.
            Please find attached some pictures of the assembly + first impressions of the running mirror.
            (due to i still struggling to bring my java software to the raspberry, there are some cables to the laptop who will disappear in the final setup).
            Overall I´m satisfied, I believe I need to play a little bit with the light conditions and install a spot on top of the mirror to compensate the light absorbation of the mirror.
            Might it be possible to craft a glass working like a “silver reflected sun-glass”?
            ? A 2 Replies Last reply Reply Quote 1
            • L Offline
              lolobyte
              Hi @mantha , great to see your mirror goal without any broken corners. ;-)
              Nice work. Great idea with your AL-Rail.
              What kind of modules you are using? Standard?
              I don’t think so!
                mantha
                No it is a own development! The objective of the project was to get in touch with advanced AI and IoT.
                I struggled to get this working with Node.js and python. So I failed back to Java with a Javafx frontend.
                  Binog
                  hey look awesome ! Are you willing to share that with the community?
                    mantha @Binog
                    @Binog sure, once when it is finished. Currently there are some “workarounds” like hard coded login to mercedes connect.me for controlling the auxheat what prevent me from sharing…
                    JerryPJ 1 Reply Last reply Reply Quote 0
                      sero @mantha
                      @mantha
                      The image of the car interieur is from the Mercedes Connect Me webapp, isn’t it? 👍 Did you manage to show/control the auxheat from your mirror?
                        A Former User @mantha
                        @mantha Nice work! Can you please post a picture from the rear side?
                        • W Offline
                          Woody
                          Hi all you DIYer !
                          got my mirror finished this weekend and just want to show you the result. Unfortunately, the mirrorglas itself is not what I’ve expected, in particuler under my light conditions it’s to dark. Maybe I’ll replace it in the future. Anyway this should not come over as criticism, @Goldjunge_Chriz made a great job and and I want to say thanks again.0_1492519591578_Pic001.jpg 0_1492519807695_Pic002.jpg 0_1492519832547_Pic003.jpg
                          A 1 Reply Last reply Reply Quote 1
                            Advokaten @Woody
                            @Woody what happens if you add a light source above or in front of the mirror? Does it seem “clearer”??
                              Advokaten @mantha
                              @mantha I love the design you made with the frame. Any possibility of revealing where you found the materials (particularly the aluminum)? Also, what size is the mirror and monitor? :) Thanks
                              • W Offline
                                Woody
                                @Advokaten Yes, I tried several light scenarios with different but not satisfying results.
                                  A Former User @Woody
                                  @Woody Are you happy with your mirror choice?
                                    Ali Baba
                                    With which glue can i fix the mirror at a wodden plate? I try it at weekend with mirror Mounting Tape from Tesa at the edges of the mirror but some hours later the mirror
                                    Dissolved itself. The other problem is that the tape is white and so i can see it Through the mirror.
                                    At next i will try “tesa doppelseitiges Montageband Powerbond”. This is black and so i hope that it would be nott seen through the mirror.
                                      A Former User @Ali Baba
                                      @Ali-Baba Realy nice idea and work. Instead of glue or tapes you can use a alu u-strip screwed to the wodden plate. So you can remove the mirror easier in the future.
                                        Ali Baba
                                        Good Idea but i´m worry that the mirror is than not ckose to the wood and it will comes some light behind the mmirror.
                                          @Ali-Baba The u-strip can be a little bit embedded or you can use felt. ;)
                                          • G Offline
                                            Goldjunge_Chriz
                                            Hello guys,
                                            we still need some great Magicmirror pictures for the Onlineshop. I would be very happy if some of you could take some nice pictures of the finish mirror and make them available to us. Many thanks in advance :)
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 28 / 28
