    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 3.0m Views 60 Watching
      A Former User @mantha
      @mantha Nice work! Can you please post a picture from the rear side?
      • W
        Woody
        Hi all you DIYer !
        got my mirror finished this weekend and just want to show you the result. Unfortunately, the mirrorglas itself is not what I’ve expected, in particuler under my light conditions it’s to dark. Maybe I’ll replace it in the future. Anyway this should not come over as criticism, @Goldjunge_Chriz made a great job and and I want to say thanks again.0_1492519591578_Pic001.jpg 0_1492519807695_Pic002.jpg 0_1492519832547_Pic003.jpg
        A 1 Reply Last reply
        • A
          Advokaten @Woody
          @Woody what happens if you add a light source above or in front of the mirror? Does it seem “clearer”??
          • A
            Advokaten @mantha
            @mantha I love the design you made with the frame. Any possibility of revealing where you found the materials (particularly the aluminum)? Also, what size is the mirror and monitor? :) Thanks
            • W
              Woody
              @Advokaten Yes, I tried several light scenarios with different but not satisfying results.
              ? 1 Reply Last reply
                A Former User @Woody
                @Woody Are you happy with your mirror choice?
                • A
                  Ali Baba
                  With which glue can i fix the mirror at a wodden plate? I try it at weekend with mirror Mounting Tape from Tesa at the edges of the mirror but some hours later the mirror
                  Dissolved itself. The other problem is that the tape is white and so i can see it Through the mirror.
                  At next i will try “tesa doppelseitiges Montageband Powerbond”. This is black and so i hope that it would be nott seen through the mirror.
                    A Former User @Ali Baba
                    @Ali-Baba Realy nice idea and work. Instead of glue or tapes you can use a alu u-strip screwed to the wodden plate. So you can remove the mirror easier in the future.
                    • A
                      Ali Baba
                      Good Idea but i´m worry that the mirror is than not ckose to the wood and it will comes some light behind the mmirror.
                        @Ali-Baba The u-strip can be a little bit embedded or you can use felt. ;)
                        • G
                          Goldjunge_Chriz
                          Hello guys,
                          we still need some great Magicmirror pictures for the Onlineshop. I would be very happy if some of you could take some nice pictures of the finish mirror and make them available to us. Many thanks in advance :)
                          • G
                            Goldjunge_Chriz
                            Here you will find a very nice video of @mantha , who used my mirror for his project.
                            https://forum.magicmirror.builders/topic/2728/my-smartmirror-based-on-goldjunge_chriz-glass
                            Finally someone shows impressively a few results with the glass :)
                            I would be very happy if more such videos and pictures of all of you would be presented here. Above all, we also need a bit of visual material for the online shop. We would be happy if some of you would provide us with a few files here. Thank you very much.
                            • JerryPJ
                              JerryP @mantha
                              @mantha
                              Hello, we have a Mercedes B250E and would like to have the connection with the Mercedes.me
                              I saw that you were working on it. Did it finally work at the end?
                              Can you help us out whit this?
                              Dankjewel Thanks frome Holland
                              • 24
                              • 25
                              • 26
                              • 27
                              • 28
                              • 28 / 28
