    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 2.9m Views 60 Watching
      Binog
      hey look awesome ! Are you willing to share that with the community?
        mantha @Binog
        @Binog sure, once when it is finished. Currently there are some “workarounds” like hard coded login to mercedes connect.me for controlling the auxheat what prevent me from sharing…
        JerryPJ 1 Reply Last reply Reply Quote 0
          sero @mantha
          @mantha
          The image of the car interieur is from the Mercedes Connect Me webapp, isn’t it? 👍 Did you manage to show/control the auxheat from your mirror?
            A Former User @mantha
            @mantha Nice work! Can you please post a picture from the rear side?
            • W Offline
              Woody
              Hi all you DIYer !
              got my mirror finished this weekend and just want to show you the result. Unfortunately, the mirrorglas itself is not what I’ve expected, in particuler under my light conditions it’s to dark. Maybe I’ll replace it in the future. Anyway this should not come over as criticism, @Goldjunge_Chriz made a great job and and I want to say thanks again.0_1492519591578_Pic001.jpg 0_1492519807695_Pic002.jpg 0_1492519832547_Pic003.jpg
              A 1 Reply Last reply Reply Quote 1
                Advokaten @Woody
                @Woody what happens if you add a light source above or in front of the mirror? Does it seem “clearer”??
                  Advokaten @mantha
                  @mantha I love the design you made with the frame. Any possibility of revealing where you found the materials (particularly the aluminum)? Also, what size is the mirror and monitor? :) Thanks
                  • W Offline
                    Woody
                    @Advokaten Yes, I tried several light scenarios with different but not satisfying results.
                      A Former User @Woody
                      @Woody Are you happy with your mirror choice?
                        Ali Baba
                        With which glue can i fix the mirror at a wodden plate? I try it at weekend with mirror Mounting Tape from Tesa at the edges of the mirror but some hours later the mirror
                        Dissolved itself. The other problem is that the tape is white and so i can see it Through the mirror.
                        At next i will try “tesa doppelseitiges Montageband Powerbond”. This is black and so i hope that it would be nott seen through the mirror.
                          A Former User @Ali Baba
                          @Ali-Baba Realy nice idea and work. Instead of glue or tapes you can use a alu u-strip screwed to the wodden plate. So you can remove the mirror easier in the future.
                            Ali Baba
                            Good Idea but i´m worry that the mirror is than not ckose to the wood and it will comes some light behind the mmirror.
                              @Ali-Baba The u-strip can be a little bit embedded or you can use felt. ;)
                              • G Offline
                                Goldjunge_Chriz
                                Hello guys,
                                we still need some great Magicmirror pictures for the Onlineshop. I would be very happy if some of you could take some nice pictures of the finish mirror and make them available to us. Many thanks in advance :)
                                • G Offline
                                  Goldjunge_Chriz
                                  Here you will find a very nice video of @mantha , who used my mirror for his project.
                                  https://forum.magicmirror.builders/topic/2728/my-smartmirror-based-on-goldjunge_chriz-glass
                                  Finally someone shows impressively a few results with the glass :)
                                  I would be very happy if more such videos and pictures of all of you would be presented here. Above all, we also need a bit of visual material for the online shop. We would be happy if some of you would provide us with a few files here. Thank you very much.
                                  • JerryPJ Offline
                                    JerryP @mantha
                                    @mantha
                                    Hello, we have a Mercedes B250E and would like to have the connection with the Mercedes.me
                                    I saw that you were working on it. Did it finally work at the end?
                                    Can you help us out whit this?
                                    Dankjewel Thanks frome Holland
                                    • 24
                                    • 25
                                    • 26
                                    • 27
                                    • 28
                                    • 28 / 28
