    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 2.9m Views 60 Watching
      Ali Baba
      Today Finale My mirror arrived. All Fine. Trank you Chris for your exzellent work.👍🏽
        Binog
        @Goldjunge_Chriz Yes I am very satisfied !
        @Hawking I used a official Raspberry NoIR Camera attached via the wired-band to the cis-port of a Raspberry 3. The attachments to the mirror is kind of special, cause it is depending of ones setting.
        As You can see in the pictures I used the cut-off of the pass-par-tout as a first framework, pooled two screws in it, unfortunately one was shorter than the other one, that is, in the other picture, You realized the camera is odd, but that doesn’t matter as I didn’t want to take photos rather then detect motion. The image by raspistill is very unsharp, but that isn’t important either. It does what it does, detecting motion.
        As the pass-par-tout is kind of foam I could screw-in the screw directly. In total the framework fits neatly between monitor and mirror-frame.
        Hopefully that helps build Your mirror.
          Binog
          Hey folks, could You please post some photos, how You fixed the mirrorglas to Your framework!? Thank You !
          • L Offline
            lolobyte @Goldjunge_Chriz
            @Hawking
            Here is my Cam picture behind the mirror from @Goldjunge_Chriz.
            RaspiCam with old mirror glass
            RaspiCam with new mirror glass
            my Mirror
            H 1 Reply Last reply Reply Quote 3
            • T Offline
              tomster @Advokaten
              @Advokaten
              Thank you very much for the kind offer. But having had a good sleep or two over the issue I managed to find peace with myself again ;-) All in all it’s just a broken mirror…
              I did order a second mirror along with the first and decided to simply change my plans for its use. I went to my local glass shop and asked them to cut it in half. That way I will end up with 2 mirrors. Ok, they are different in size now, but hey? I will end up with 2 mirrors still :)
              Again, I really do appreciate your offer as it proves a hell of a lot in regards of community spirit. Especially since it is not the fault of any of you. I do hope though that you do not bother that I have to turn down your offer. Everything is fine.
              • H Offline
                Hawking @lolobyte
                Thanks for the pictures.
                @lolobyte said in [ORDER CLOSED] Two way mirror order in Germany:
                @Hawking
                What do you mean by “old mirror glass” and “new mirror glass”? Anyway, both pictures look very good, I hope that even gesture detection trough the glass should be possible. Can you also provide details how you attached the raspi-camera (regular or also noir variant?) at the back of the mirror?
                • L Offline
                  lolobyte @Hawking
                  @Hawking
                  like @Goldjunge_Chriz said and i mentioned, the new mirror glass is the one from @Goldjunge_Chriz .
                  My setup is like this.
                    Advokaten @lolobyte
                    @lolobyte, and the front/side?? Thanks!
                    • L Offline
                      lolobyte
                      is the mirror???
                      • L Offline
                        lolobyte @Advokaten
                        @Advokaten maybe this will help you!
                          mantha
                          Hi together,
                          long weekend - perfect to finish the mirror hardware.
                          Please find attached some pictures of the assembly + first impressions of the running mirror.
                          (due to i still struggling to bring my java software to the raspberry, there are some cables to the laptop who will disappear in the final setup).
                          Overall I´m satisfied, I believe I need to play a little bit with the light conditions and install a spot on top of the mirror to compensate the light absorbation of the mirror.
                          Might it be possible to craft a glass working like a “silver reflected sun-glass”?
                          ? A 2 Replies Last reply Reply Quote 1
                          • L Offline
                            lolobyte
                            Hi @mantha , great to see your mirror goal without any broken corners. ;-)
                            Nice work. Great idea with your AL-Rail.
                            What kind of modules you are using? Standard?
                            I don’t think so!
                              mantha
                              No it is a own development! The objective of the project was to get in touch with advanced AI and IoT.
                              I struggled to get this working with Node.js and python. So I failed back to Java with a Javafx frontend.
                                Binog
                                hey look awesome ! Are you willing to share that with the community?
                                  mantha @Binog
                                  @Binog sure, once when it is finished. Currently there are some “workarounds” like hard coded login to mercedes connect.me for controlling the auxheat what prevent me from sharing…
                                  JerryPJ 1 Reply Last reply Reply Quote 0
                                    sero @mantha
                                    @mantha
                                    The image of the car interieur is from the Mercedes Connect Me webapp, isn’t it? 👍 Did you manage to show/control the auxheat from your mirror?
                                      [[global:former-user]] @mantha
                                      @mantha Nice work! Can you please post a picture from the rear side?
                                      • W Offline
                                        Woody
                                        Hi all you DIYer !
                                        got my mirror finished this weekend and just want to show you the result. Unfortunately, the mirrorglas itself is not what I’ve expected, in particuler under my light conditions it’s to dark. Maybe I’ll replace it in the future. Anyway this should not come over as criticism, @Goldjunge_Chriz made a great job and and I want to say thanks again.0_1492519591578_Pic001.jpg 0_1492519807695_Pic002.jpg 0_1492519832547_Pic003.jpg
                                        A 1 Reply Last reply Reply Quote 1
                                          Advokaten @Woody
                                          @Woody what happens if you add a light source above or in front of the mirror? Does it seem “clearer”??
                                            Advokaten @mantha
                                            @mantha I love the design you made with the frame. Any possibility of revealing where you found the materials (particularly the aluminum)? Also, what size is the mirror and monitor? :) Thanks
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 27 / 28
