    Blackscreen after install MMM-PIR-Sensor
    15 Posts 5 Posters 9.2k Views 4 Watching
      Blackmirror
      I have it remove and make a new installation, after this it comes errors:
      pi@Mirror:~/MagicMirror/modules/MMM-PIR-Sensor $ sudo npm install -g
      epoll@0.1.21 install /usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor/node_modules/epoll
      node-gyp rebuild
      gyp WARN EACCES user “root” does not have permission to access the dev dir “/root/.node-gyp/6.10.0”
      gyp WARN EACCES attempting to reinstall using temporary dev dir “/usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor/node_modules/epoll/.node-gyp”
      make: Entering directory ‘/usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor/node_modules/epoll/build’
      CXX(target) Release/obj.target/epoll/src/epoll.o
      SOLINK_MODULE(target) Release/obj.target/epoll.node
      COPY Release/epoll.node
      make: Leaving directory ‘/usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor/node_modules/epoll/build’
      Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor
      electron-rebuild -e …/…/node_modules/electron
      sh: 1: electron-rebuild: not found
      npm ERR! Linux 4.4.50-v7+
      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install” “-g”
      npm ERR! node v6.10.0
      npm ERR! npm v3.10.10
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: electron-rebuild -e ../../node_modules/electron
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script ‘electron-rebuild -e …/…/node_modules/electron’.
      npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
      npm ERR! not with npm itself.
      npm ERR! electron-rebuild -e …/…/node_modules/electron
      npm ERR! npm bugs Magic-Mirror-Module-PIR-Sensor
      npm ERR! Or if that isn’t available, you can get their info via:
      npm ERR! npm owner ls Magic-Mirror-Module-PIR-Sensor
      npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
      • cowboysdudeC Offline
        Did you go to the module directory that the pir module is in and run ‘npm install’?
        If not try that first.
          Blackmirror
          I have delete the ‘,’ but I have still this problem. In the past failure in the config.js make a white screen at me.
          And I have run ‘sudo npm install -g’ in the MMM-PIR-Sensor directory,
          and I see this Error messages. And I have still a black screen.
          • brobergB Offline
            broberg Project Sponsor
            I don’t think you are supposed to be using sudo when doing npm install just the other parts,
            Using sudo will probably give access issues for the module.
              Blackmirror
              So I Have rm -rf MMM-PIR-Sensor and new install. after this I run npm install -g, is give the follow error messages
              pi@Mirror:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install -g
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules
              /usr/lib
              └─┬ Magic-Mirror-Module-PIR-Sensor@1.1.0
              └─┬ onoff@1.1.2
              └─┬ epoll@0.1.21
              ├── bindings@1.2.1
              └── nan@2.5.1
              npm ERR! path /usr/lib/node_modules
              npm ERR! code EACCES
              npm ERR! errno -13
              npm ERR! syscall access
              npm ERR! Error: EACCES: permission denied, access ‘/usr/lib/node_modules’
              npm ERR! at Error (native)
              npm ERR! { Error: EACCES: permission denied, access ‘/usr/lib/node_modules’
              npm ERR! errno: -13,
              npm ERR! code: ‘EACCES’,
              npm ERR! syscall: ‘access’,
              npm ERR! path: ‘/usr/lib/node_modules’ }
              npm ERR!
              npm ERR! Please try running this command again as root/Administrator.
              And a black screen at the mirror
                Blackmirror
                I Have solve this problem without MMM-PIR-Sensor this a python-skript in rc.local.
                But bei DHT22 - Sensor is not working now, destroyed? But why?
                • H Offline
                  howesfam
                  Hi Blacjscreen,
                  I’m suffering the same problems, do you have alink to your python code?
                    Blackmirror @howesfam
                    @howesfam
                    import RPi.GPIO as GPIO
                    import time
                    #Board Mode: Angabe der Pin-Nummer
                    GPIO.setmode(GPIO.BOARD)
                    #GPIO Pin definieren fuer den Dateneingang vom Sensor
                    PIR_GPIO = 13
                    Relay_GPIO = 37
                    GPIO.setup(PIR_GPIO, GPIO.IN)
                    GPIO.setup(Relay_GPIO, GPIO.OUT)
                    GPIO.output(Relay_GPIO, True)
                    GPIO.setup(32,GPIO.IN)
                    read=0
                    wait=0
                    ein=0
                    button=1
                    while True :
                       #PIR auslesen
                       read = GPIO.input(PIR_GPIO)
                       button = GPIO.input(32)
                       if ((read==1 or button==0) and wait==0):
                         GPIO.output(Relay_GPIO, False)
                         wait=1
                         ein=1
                         time.sleep(0.5)
                       elif ein==1 and button==0:
                         ein=0
                         time.sleep(0.5)
                    Have found in the web and I have modified for me, the Pin 32 is a button to make the monitor, ampilifier and the mirror light always on.
                      beck0r
                      Having the same problem. Any solution ?
                        Blackmirror
                        Use the PIR-Senosr not with this modul, but with the python script.
