Blackscreen after install MMM-PIR-Sensor
15 Posts 5 Posters 8.1k Views 4 Watching
    Blackmirror
    it’s my first entry here.
    I will start to build a MagicMirror and I have a Problem with the MMM-PIR_Sensor Modul.
    I have installed and have no problems at the install, but will the Mirror start I see only a black screen. When I move the mouse at the raspberry I can see the mouse arrow.
    When I unmarker the PIR-Module lines in the config.js . I can see the normal Mirror.
      post your config.js minus any keys so we can take a peek…
        Blackmirror
        Here, but I think it is not a problem with the config.js, because when I have the module in the config.js include and deinstall the module in Magicmirror/modules I can see the Mirror:
        var config = {
                port: 8080,
                language: 'de',
                timeFormat: 24,
                units: 'metric',
                                module: 'alert',
        //              module: 'MMM-PIR-Sensor',
        //              config: {
        //              relayGpio: '26',
        //              relayOnState: '0',
        //              powerSaving: false,
        //                      // See 'Configuration options' for more information.
                    module: 'MMM-Carousel',
                        transitionInterval: 10000,
                        ignoreModules: [],
                        mode: 'positional',
                        top_right: {enabled: true, ignoreModules: [], overrideTransitionInterval: 15000}
                                module: "updatenotification",
                                position: "top_bar"
                        module: 'MMM-FRITZ-Box-Callmonitor',
                        //position: 'top_bar',  // This can be any of the regions. Best results in left or right regions.
                        //header: "Recent calls", // This is optional
                        config: { password: 'xxx'
                        module: 'MMM-Callmonitor-Current-Call',
                        //header: "Active Calls", // This is optional
                                module: 'clock',
                                position: 'top_left'
                            module: 'MMM-DHT22',
                                position: 'top_left',
                              sensorPIN: 22,
                               updateInterval: 0.5, // Minutes
                                module: 'currentweather',
                                        locationID: 'xxx',  //ID from http://www.openweathermap.org
                                        appid: 'xxx'
                module: 'MMM-Traffic',
                classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                        api_key: 'xxx',
                        mode: 'driving',
                        origin: 'xxx',
                        destination: 'xxx',
                        //arrival_time: '0800', //optional, but needs to be in 24 hour time if used.
                        route_name: 'xxx',
                        changeColor: true,
                        showGreen: false,
                        limitYellow: 5, //Greater than 5% of journey time due to traffic
                        limitRed: 20, //Greater than 20% of journey time due to traffic
                        traffic_model: 'pessimistic',
                        interval: 120000, //2 minutes
                        showWeekend: true,
                        allTime: true,
                                module: 'calendar',
                                header: 'Termine',
                                position: 'top_right',
                                                        symbol: 'calendar-check-o ',
                                                        url: 'xxxs',
                                                        maximumEntries: '5'
                            module: "MMM-Fuel",
                                api_key: "xxx",
                        lat: xxx,
                                lng: xxx,
                                 types: ["diesel"],
                                max: 2,
                                rotate: false,
                                colored: true,
                                open: true
        //                               module: 'MMM-Wunderlist',
        //                      position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
        //                      header: 'Wunderlist', // This is optional
        //                      config: {
                                module: 'weatherforecast',
                                header: 'Weather Forecast',
                                        appid: 'xxx'
        //                      module: 'newsfeed',
        //                      position: 'bottom_bar',
        //                      config: {
        //                              feeds: [
        //                                              title: "xxx",
        //                                              url: "xxxl"
        //                              showSourceTitle: true,
        //                              showPublishDate: true
          @Blackmirror said in Blackscreen after install MMM-PIR-Sensor:
          // module: ‘MMM-PIR-Sensor’,
          // config: {
          // relayGpio: ‘26’,
          // relayOnState: ‘0’,
          // // See ‘Configuration options’ for more information.
          Right off the top here is an issue :) should only have one }, :) Like this below…
          It has too many }, so it’s stopping at the first one then errors out because it goes to the next }, as a new line and that creates your problem. :)
          relayGpio: ‘26’,
          relayOnState: ‘0’,
          powerSaving: false,
          B 1 Reply Last reply Apr 13, 2017, 12:46 PM Reply Quote 1
            Blackmirror @cowboysdude
            @cowboysdude
            No, this is not the problem, I have unlined this, because I can not use the Mirror, when I delete the // I see the black screen.
            It’s my fault to show the config.js this the //.
              Blackmirror
              I have it remove and make a new installation, after this it comes errors:
              pi@Mirror:~/MagicMirror/modules/MMM-PIR-Sensor $ sudo npm install -g
              epoll@0.1.21 install /usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor/node_modules/epoll
              node-gyp rebuild
              gyp WARN EACCES user “root” does not have permission to access the dev dir “/root/.node-gyp/6.10.0”
              gyp WARN EACCES attempting to reinstall using temporary dev dir “/usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor/node_modules/epoll/.node-gyp”
              make: Entering directory ‘/usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor/node_modules/epoll/build’
              CXX(target) Release/obj.target/epoll/src/epoll.o
              SOLINK_MODULE(target) Release/obj.target/epoll.node
              COPY Release/epoll.node
              make: Leaving directory ‘/usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor/node_modules/epoll/build’
              Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor
              electron-rebuild -e …/…/node_modules/electron
              sh: 1: electron-rebuild: not found
              npm ERR! Linux 4.4.50-v7+
              npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install” “-g”
              npm ERR! node v6.10.0
              npm ERR! npm v3.10.10
              npm ERR! file sh
              npm ERR! code ELIFECYCLE
              npm ERR! errno ENOENT
              npm ERR! syscall spawn
              npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: electron-rebuild -e ../../node_modules/electron
              npm ERR! spawn ENOENT
              npm ERR!
              npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script ‘electron-rebuild -e …/…/node_modules/electron’.
              npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
              npm ERR! not with npm itself.
              npm ERR! electron-rebuild -e …/…/node_modules/electron
              npm ERR! npm bugs Magic-Mirror-Module-PIR-Sensor
              npm ERR! Or if that isn’t available, you can get their info via:
              npm ERR! npm owner ls Magic-Mirror-Module-PIR-Sensor
              npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                Did you go to the module directory that the pir module is in and run ‘npm install’?
                If not try that first.
                  Blackmirror
                  I have delete the ‘,’ but I have still this problem. In the past failure in the config.js make a white screen at me.
                  And I have run ‘sudo npm install -g’ in the MMM-PIR-Sensor directory,
                  and I see this Error messages. And I have still a black screen.
                    broberg Project Sponsor
                    I don’t think you are supposed to be using sudo when doing npm install just the other parts,
                    Using sudo will probably give access issues for the module.
                      Blackmirror
                      So I Have rm -rf MMM-PIR-Sensor and new install. after this I run npm install -g, is give the follow error messages
                      pi@Mirror:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install -g
                      npm WARN checkPermissions Missing write access to /usr/lib/node_modules
                      /usr/lib
                      └─┬ Magic-Mirror-Module-PIR-Sensor@1.1.0
                      └─┬ onoff@1.1.2
                      └─┬ epoll@0.1.21
                      ├── bindings@1.2.1
                      └── nan@2.5.1
                      npm ERR! path /usr/lib/node_modules
                      npm ERR! code EACCES
                      npm ERR! errno -13
                      npm ERR! syscall access
                      npm ERR! Error: EACCES: permission denied, access ‘/usr/lib/node_modules’
                      npm ERR! at Error (native)
                      npm ERR! { Error: EACCES: permission denied, access ‘/usr/lib/node_modules’
                      npm ERR! errno: -13,
                      npm ERR! code: ‘EACCES’,
                      npm ERR! syscall: ‘access’,
                      npm ERR! path: ‘/usr/lib/node_modules’ }
                      npm ERR!
                      npm ERR! Please try running this command again as root/Administrator.
                      And a black screen at the mirror
