    Beginner question - is this configuration possible?
    noobconfigurationvideonewbie
    4 Posts 2 Posters 3.4k Views 1 Watching
      Shrike
      Hi all, first message to this Forum, thanks in advance for taking the time to help.
      I’m somewhat experienced in integrating hardware and messing about Linux, but I am not sure if I want to build is possible so I wanted to check with you guys first.
      After seeing all these cool MM projects, I wanted to build one for our kitchen/living room. The idea is to display a family calendar, messages, etc, pretty standard stuff. However, I would like to have some rough configurability on it - to change the mode to not showing personal information when we are entertaining people for example. The UI needs to be very simple of course, no cables or input devices allowed.
      I got to thinking about a web cam and a microphone, to use gesture- and/or voice commands to provide input to the system.
      Then I started to think that if there is a webcam, could the device also be used for video calls? It would be awesome for my daughter to be able to call the grandparents, or start a quick call to my partner while cooking.
      So the feature list is:
      1. Google calendar integration
      2. Configurable modes
      3. Rough UI using gestures and/or voice commands
      4. Video call possibility
      5. Slideshow of selected family pictures when user not seen (?)
      Let me know what you think of this set-up!
        broberg Project Sponsor @Shrike
        @Shrike all above exists already except for nr.4 which is the only one that could be a issue due to the lack of power on the raspberry I think.
          Shrike @broberg
          @broberg Great, thank you!
          Is there a standard set of “most likely to work” -hardware (PI+Webcam+power hub) that would provide the least amount of hassle?
            @Shrike Since I don’t use a cam to my setup I can’t really tell.
            But I guess the easiest is going all Raspberry PI (stock power supply, raspberry camera and a pi 3)
