    CSS "z-index" is not working anymore
    11 Posts 3 Posters 10.0k Views 2 Watching
      davidnesbitt7
      Does it have a defined position? i.e position: absolute; or position: fixed; as far as I know z-index will only work when the div has a defined position
      Do. Or do not. There is no try
      iMAGiCI 1 Reply Last reply Reply Quote 0
      • iMAGiCI Offline
        iMAGiC @davidnesbitt7
        @davidnesbitt7 thanks, it should be absolute, I didn’t change others, just add z-index= -1 or 1
        Choice * Judgment * Values
          davidnesbitt7
          I just put a background on mine and it seemed to go in without the need for a z-index and behind everything else, I used
          html:before {
                     background-image: url(http://YOUR URL HERE);
                     content: '';
                     height: 100%;
                     position: absolute;
                     width: 100%;
          body {
                background: transparent;
          I just changed the background color on the body to transparent because in main.css it’s set to black and will show over the background image, this worked for me hope it helps you, you can also set things like background-size: cover; if you want to stretch the image to be full width and background-repeat: no-repeat; if more than one image shows
          • iMAGiCI Offline
            @davidnesbitt7
            thanks for the solution.
            I am using MMM-RandomPhoto module, it can get 1080x1920 picture automatically and change in every 60 seconds.
            				module: 'MMM-RandomPhoto',
            				position: 'fullscreen_above',
            					opacity: 0.4,
            			        	animationSpeed: 2000,
            			        	updateInterval: 600,
            			        	url: 'https://unsplash.it/1080/1920/?random' //1080x160
            Maybe I can try add something in .js file below:
            https://github.com/diego-vieira/MMM-RandomPhoto/blob/master/MMM-RandomPhoto.js
              davidnesbitt7
              @iMAGiC Oh…I’m not familiar with that module, I can see that you have position: 'fullscreen_above'; maybe try position: 'fullscreen_below' and see if that changes it to be below for you?
              iMAGiCI 2 Replies Last reply Reply Quote 0
              • iMAGiCI Offline
                @davidnesbitt7 I’ve tried that, but not succeed… :disappointed:
                thanks for your time, I will try others later…
                • iMAGiCI Offline
                  @davidnesbitt7 finally I got some thing, I was add z-index in wrong place.
                  I am now add z-index in MMM-RandomPhoto.js:
                  img id="mmm-photos-placeholder1" style="z-index=-1;opacity: 0; position: absolute" img id="mmm-photos-placeholder2" style="z-index=-1;opacity: 0; position: absolute"
                  and remark background in main.css:
                   // background: #000;
                  now it works, only issue is picture not shows from top, but it’s minor, when display behind mirror. :grin:
                  • brobergB Offline
                    broberg Project Sponsor @iMAGiC
                    @iMAGiC you shouldn’t edit the module code or the main.css file.
                    You should do all css alterations in the custom.css file
                    like background: none in the body{} tag and add
                    #mmm-photos-placeholder1 {position: absolute; z-index: -1; opacity: 0}
                    #mmm-photos-placeholder2 {position: absolute; z-index: -1; opacity: 0}
                    to your custom.css
                    • iMAGiCI Offline
                      iMAGiC @broberg
                      @broberg Yes, I will modify it later.
                      • iMAGiCI Offline
                        iMAGiC @broberg
                        @broberg all set, thank you~
                        in custom.css
                        html {
                          cursor: none;
                          overflow: hidden;
                         .region.fullscreen * {
                          pointer-events: auto;
                          position: top;
                          top: 0px;
