Solved [ORDER CLOSED] Two way mirror order in Germany
is the mirror???
@Advokaten maybe this will help you!
Hi together,
long weekend - perfect to finish the mirror hardware.
Please find attached some pictures of the assembly + first impressions of the running mirror.
(due to i still struggling to bring my java software to the raspberry, there are some cables to the laptop who will disappear in the final setup).Overall I´m satisfied, I believe I need to play a little bit with the light conditions and install a spot on top of the mirror to compensate the light absorbation of the mirror.
Might it be possible to craft a glass working like a “silver reflected sun-glass”?
Hi @mantha , great to see your mirror goal without any broken corners. ;-)
Nice work. Great idea with your AL-Rail.
What kind of modules you are using? Standard?
I don’t think so! -
No it is a own development! The objective of the project was to get in touch with advanced AI and IoT.
I struggled to get this working with Node.js and python. So I failed back to Java with a Javafx frontend. -
hey look awesome ! Are you willing to share that with the community?
@Binog sure, once when it is finished. Currently there are some “workarounds” like hard coded login to mercedes connect.me for controlling the auxheat what prevent me from sharing…
@mantha
The image of the car interieur is from the Mercedes Connect Me webapp, isn’t it? 👍 Did you manage to show/control the auxheat from your mirror? -
@mantha Nice work! Can you please post a picture from the rear side?
Hi all you DIYer !
got my mirror finished this weekend and just want to show you the result. Unfortunately, the mirrorglas itself is not what I’ve expected, in particuler under my light conditions it’s to dark. Maybe I’ll replace it in the future. Anyway this should not come over as criticism, @Goldjunge_Chriz made a great job and and I want to say thanks again.
