    AlexaPi
    28 Posts 4 Posters 16.5k Views 4 Watching
      davidrq7
      Guys i need help. I have no idea from where should i get this AVS refresh token.
      any1 can help?
      lucallmonL johnnyboyJ 2 Replies Last reply Reply Quote 0
      • lucallmonL Offline
        lucallmon @davidrq7
        @davidrq7 check with the guys here: gitter.im/AlexaPi
        • johnnyboyJ Offline
          johnnyboy @davidrq7
          johnnyboyJ 1 Reply Last reply Reply Quote 0
            johnnyboy @johnnyboy
              davidrq7 @johnnyboy
              @johnnyboy dunno why, guess i make a mistake. but now i reinstall AlexaPi and make everythink step by step and i have error when i use to use my LocalIp:5050 0_1492682163943_error.jpg
                johnnyboy @davidrq7
                  davidrq7 @johnnyboy
                  @johnnyboy ill wait mby it will be ok. But i found at forum somethink like this" Description of problem:
                  If you already have a config file the installer will ask if you want to Keep, Edit or Delete, choosing Keep it does exit the installer even if there is no token saved in the config file. You need to run manually python auth_web.py to finish the configuration."
                  Do you think it will help it this case? How should i run it btw?
                    johnnyboy @davidrq7
                        davidrq7 @johnnyboy
                        @johnnyboy thx so ill just wait for Amazon response . Thx for Your time!
