    AlexaPi
    28 Posts 4 Posters 19.2k Views 4 Watching
    • johnnyboyJ
      johnnyboy @davidrq7
      johnnyboyJ 1 Reply Last reply Reply Quote 0
      • johnnyboyJ
        johnnyboy @johnnyboy
          davidrq7 @johnnyboy
          @johnnyboy dunno why, guess i make a mistake. but now i reinstall AlexaPi and make everythink step by step and i have error when i use to use my LocalIp:5050 0_1492682163943_error.jpg
          • johnnyboyJ
            johnnyboy @davidrq7
              davidrq7 @johnnyboy
              @johnnyboy ill wait mby it will be ok. But i found at forum somethink like this" Description of problem:
              If you already have a config file the installer will ask if you want to Keep, Edit or Delete, choosing Keep it does exit the installer even if there is no token saved in the config file. You need to run manually python auth_web.py to finish the configuration."
              Do you think it will help it this case? How should i run it btw?
              • johnnyboyJ
                johnnyboy @davidrq7
                • johnnyboyJ
                    davidrq7 @johnnyboy
                    @johnnyboy thx so ill just wait for Amazon response . Thx for Your time!
                    • johnnyboyJ
                      johnnyboy @davidrq7
                      • johnnyboyJ
                        • romainR
                          romain
                          Not completly sure about this but the http server : 5055 might just be the port AlexaPi using to comunicate with the MagicMirror module MMM-AlexaPi . I do have the same message and it doesn’t prevent AlexaPi to work
                            davidrq7
                            Guys i get a little succes.
                            I got the token from amazon, i set the sound and when i start alexa service she is active but i got rly nasty problem with this port 5055. I have no idea what to do next0_1492711999352_18034766_1562333477133204_1450890660_n.jpg
                            romainR 1 Reply Last reply Reply Quote 0
                            • romainR
                              romain @davidrq7
                              @davidrq7 This mean you have already an instance of alexaPi running. reboot or kill the already running alexapi
                                davidrq7
                                Y, but even when i stop alexa service and start it again it looks all the same. Any sugestions? :) im getting closer to the end ^^
                                • johnnyboyJ
                                  johnnyboy @davidrq7
                                    davidrq7 @johnnyboy
                                    @johnnyboy i’ll check this tomorrow by using sudo netstat -lnptu to check which application is blocking 5055 or 5050 port
                                    • johnnyboyJ
                                      johnnyboy @davidrq7
                                      • L
                                        lucallmon
                                        i had errors installing the current version 1.5, so I reverted back to v1.4 which is much more stable. this is the version that I am currently running flawlessly.
                                        cd /opt/AlexaPi
                                        sudo git checkout v1.4
                                        I hope this helps
                                        • johnnyboyJ
                                          johnnyboy @lucallmon
                                            davidrq7
                                            This is what i got when i used netstat. Dont know what should i do next?
                                            0_1492777811244_18052991_1563534897013062_29793805_n.jpg0_1492778637066_18052791_1563556803677538_1550604459_n.jpg0_1492778810487_1563565440343341_1253734879_n.jpg
                                            Edit: Allright i found something. sudo nano /etc/opt/AlexaPi/config.yaml at bottom is a line with numer 5055 so i change it for 5050. Diging more …;)
