    AlexaPi
    28 Posts 4 Posters 16.9k Views 4 Watching
    • johnnyboyJ Offline
      johnnyboy @davidrq7
      johnnyboyJ 1 Reply Last reply Reply Quote 0
        johnnyboy @johnnyboy
          davidrq7 @johnnyboy
          @johnnyboy dunno why, guess i make a mistake. but now i reinstall AlexaPi and make everythink step by step and i have error when i use to use my LocalIp:5050 0_1492682163943_error.jpg
            johnnyboy @davidrq7
              davidrq7 @johnnyboy
              @johnnyboy ill wait mby it will be ok. But i found at forum somethink like this" Description of problem:
              If you already have a config file the installer will ask if you want to Keep, Edit or Delete, choosing Keep it does exit the installer even if there is no token saved in the config file. You need to run manually python auth_web.py to finish the configuration."
              Do you think it will help it this case? How should i run it btw?
                johnnyboy @davidrq7
                    davidrq7 @johnnyboy
                    @johnnyboy thx so ill just wait for Amazon response . Thx for Your time!
                      johnnyboy @davidrq7
