    Office 365 calendar issues
    16 Posts 5 Posters 13.1k Views 5 Watching
    • H Offline
      hermpi @cohron
      @cohron I just start up my PI and yes the calendar works partially… I don’t know if the reason is the deleting of the re-announcing tasks or there was something wrong with the server Sunday night. De strange thing is that most of my tasks show a invalid date error. Only the tasks that have the “whole day” option checked are displaying correctly. I don’t know if you familiar with ICS files but I think it has to do with these line of codes:
      // This works (Whole day checked)
      DTSTART;VALUE=DATE:20170421
      DTEND;VALUE=DATE:20170423
      // This gives invalid date error
      DTSTART;TZID="(UTC+01:00) Amsterdam, Berlijn, Bern, Rome, Stockholm, Wenen":2
       0170412T080000
      DTEND;TZID="(UTC+01:00) Amsterdam, Berlijn, Bern, Rome, Stockholm, Wenen":201
       70412T090000
      Could you check what is set for DTSTART and DTEND in your ICS file?
      C 2 Replies Last reply Reply Quote 0
        cohron @hermpi
        @hermpi
        Oh, yes some of my tasks had the invalid date error, only 4 or 5 tasks though. It was only occurring on appointments that had the timezone showing. Unfortunately I already fixed it by removing the (show) timezones and resaving the appointment. Sorry didnt catch that earlier. I set up a test appointment and will look at the MM when I get home. I havent picked apart the Calendar MMM but im guessing you found the same bug i had. Wont know if i recreated the error until i get him and look at MM.
        Keep your “bad” ICS file for the programmers (or you) to test, recreate, and fix if you submit a bug report.
        0_1492625512666_upload-34952624-9688-450d-8dd1-228c1a1e4996
        0_1492626000390_upload-b53fa3a9-eb5a-4678-abe3-c9a1afa4d953
        0_1492626080044_upload-e7bc8dc2-946f-46fa-a163-a11fe089a2d2
          cohron @hermpi
          @hermpi
          Well i checked my calendar and everything looked fine. I havent been able to get the invalid date to show up again (even with timezones enabled/showing). I’d say open a bug report and send them your ICS file.
          should be fine really.
          H 2 Replies Last reply Reply Quote 0
          • H Offline
            hermpi @cohron
            @cohron Oke, I will do that. I just checked my own calendar again and only if I save the appointment in timezone “Coordinated Universal Time” it works. Or if I set my overall timezone to UTC… But that’s not a solution because then everything is set to that time and I’m living in the UTC+1 zone.
            • H Offline
              hermpi @cohron
              @cohron (#*$&,. I just figured out that this only happens when you set to a time zone with multiple cities… So i can set the timezone to a same one as I live in with only one name like: “UTC+01:00 Windhoek”. I ask if this is a problem we/they need to fix in MM or that our big friend from Microsoft had to set up there ical files right. I keep you updated ;)
                cohron @hermpi
                @hermpi said in Office 365 calendar issues:
                I’m going to guess MM is going to have to fix their parsing, it appears to be a well formed ics file (or at least the portion you and i looked at), I doubt we are going to get Microsoft to change.
                • H Offline
                  hermpi @cohron
                  @cohron Everything works fine now thanks to: https://github.com/MichMich/MagicMirror/pull/875
                  cheers!
                  • bheplerB Offline
                    bhepler Module Developer @hermpi
                    @hermpi Curious. I dropped those changes into my mirror and it didn’t resolve the problem at all. Hrm.
                    • H Offline
                      hermpi @bhepler
                      @bhepler Oke first off all, sorry for my late reaction I was luckily enough to have a long vacation… :) I finally finished the housing of the mirror and planning to fasten it in my bedroom today. The last time I checked (3 days ago) my office 365 calendar runs just fine. Maybe you cant make an test appointment in your agenda and DM me the Ical file so I can check how my MM response to your generated Ical file.
                      • bheplerB Offline
                        @hermpi Will do. I’ll try to get that file to you this evening. Thanks.
