    Cant figure out how to install a module in the config.js
    19 Posts 5 Posters 14.2k Views 4 Watching
    • romainR
      romain @Edswald
      @Edswald you didn’t put the module info at the right place and you missing
              paths: {
                      modules: "modules",
                      vendor: "vendor"
      just before the do not edit the line bellow.
      Your file should look like this at the end
                              module: "newsfeed",
                              position: "bottom_bar",
                                      feeds: [
                                                      title: "New York Times",
                                      showSourceTitle: true,
                                      showPublishDate: true
      			module: 'twitControl',
      			position: 'top_left',
      				maxNumTweets: 5,
      				streamType: 'followings',
      				api_keys: {
      					consumer_key: 'YOUR CONSUMER KEY',
      					consumer_secret: 'YOUR CONSUMER SECRET',
      					access_token_key: 'YOUR ACCESS TOKEN KEY',
      					access_token_secret: 'YOUR ACCESS TOKEN SECRET'
              paths: {
                      modules: "modules",
                      vendor: "vendor"
      • E
        Edswald
        ok so is this correct or am i suppose to put somthing in where it says modules and vendor. Its till not running 0_1493057568851_2017-04-24-120637_1280x1024_scrot.png
        B 1 Reply Last reply
          broberg Project Sponsor @Edswald
          @Edswald 0_1493058241706_1493057570459-2017-04-24-120637_1280x1024_scrot.jpg
          And for future reference, past the contents of the config in text format on the forum, it will be easier to see all of the config file then.
          E 1 Reply Last reply
          • E
            Edswald @broberg
            @broberg is this right me an my team mate are here trying to see if we missed anything. Its still not running.0_1493061502651_2017-04-24-131726_1280x1024_scrot.png
              @Edswald post it as text. can’t help you with only a screenshot
              • E
                Edswald @broberg
                @broberg ok here you go
                /* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                	port: 8080,
                	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
                	language: "en",
                	timeFormat: 24,
                	units: "metric",
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			header: "US Holidays",
                						symbol: "calendar-check-o ",
                			module: "compliments",
                			position: "lower_third"
                			module: "currentweather",
                				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                			module: "weatherforecast",
                			header: "Weather Forecast",
                				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                			module: "newsfeed",
                				feeds: [
                				maxNumTweets: 5,
                				api_keys: {
                  You are using the wrong quotations,
                  you are using ’ when you should use '
                  and “ when you should use "
                  so first of change
                  ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
                  to
                  and
                  module: ‘twitControl’,
                  position: ‘top_left’,
                  maxNumTweets: 5,
                  streamType: ‘followings’,
                  api_keys: {
                  consumer_key: ‘ ’,
                  consumer_secret: ‘ ’,
                  access_token_key: ‘ ’,
                  access_token_secret: ‘ ’
                  to
                  module: "twitControl",
                  maxNumTweets: 5,
                  api_keys: {
                  consumer_key: ' ' ,
                  consumer_secret: ' ',
                  access_token_key: ' ' ,
                  access_token_secret: ' '
                  And do edit your post above to remove your personal keys!
                  • E
                    Edswald @broberg
                    @broberg Thank you very much it worked finally :)
                      @Edswald Glad to hear it!
                      • E
                        Edswald @broberg
                        @broberg umm can you help me again now im trying to install another twitter module with no luck :(
                        • E
                          Edswald
                          • MIT Licensed.
                          var config = {
                          port: 8080,
                          language: "en",
                          timeFormat: 24,
                          units: "metric",
                          		module: "alert",
                          		position: "top_bar"
                          		module: "clock",
                          		module: "newsfeed",
                          			feeds: [
                          maxNumTweets: 5,
                          api_keys: {
                          consumer_key: ‘fill’,
                          consumer_secret: ‘fill’,
                          access_token_key: ‘fill’,
                          access_token_secret: ‘fill’
                          module: ‘MMM-TwitterTrendsByPlace’,
                          position: ‘bottom_left’,
                          // visit the url below for the twitter keys/tokens
                          // https://dev.twitter.com/oauth/overview/application-owner-access-tokens
                          access_token_secret: ‘fill’,
                          // set the display name/title for the place
                          placeName: ‘New York, NY’,
                          // set the woeid for the place, see documentation for more
                          // http://woeid.rosselliot.co.nz/lookup/
                          placeWoeid: ‘2459115’,
                          if (typeof module !== “undefined”) {module.exports = config;}
                          • E
                            Edswald
                              @Edswald you have to place the modules within the brackets
                              If you go back to the picture where I marked that you should move two brackets you will see which ones I mean.
                              And when you post your config files delete your sensitiv data (like api-keyes)
                              • E
                                Edswald @broberg
                                @broberg Ahhh i see what you mean thank you again :)
