    Cant figure out how to install a module in the config.js
    19 Posts 5 Posters 14.2k Views 4 Watching
    • E
      Edswald
      ok so here how my config file looks like i blacked out my twitter info but i think its right i dont know and thanks for everyone how is helping me with this your awesome!!!0_1493046075374_17bf40e2880333d8695ffe5511d2d047.png
      romainR 1 Reply Last reply
      • romainR
        romain @Edswald
        @Edswald you didn’t put the module info at the right place and you missing
                paths: {
                        modules: "modules",
                        vendor: "vendor"
        just before the do not edit the line bellow.
        Your file should look like this at the end
                                module: "newsfeed",
                                position: "bottom_bar",
                                        feeds: [
                                                        title: "New York Times",
                                        showSourceTitle: true,
                                        showPublishDate: true
        			module: 'twitControl',
        			position: 'top_left',
        				maxNumTweets: 5,
        				streamType: 'followings',
        				api_keys: {
        					consumer_key: 'YOUR CONSUMER KEY',
        					consumer_secret: 'YOUR CONSUMER SECRET',
        					access_token_key: 'YOUR ACCESS TOKEN KEY',
        					access_token_secret: 'YOUR ACCESS TOKEN SECRET'
                paths: {
                        modules: "modules",
                        vendor: "vendor"
        • E
          Edswald
          ok so is this correct or am i suppose to put somthing in where it says modules and vendor. Its till not running 0_1493057568851_2017-04-24-120637_1280x1024_scrot.png
          B 1 Reply Last reply
            broberg Project Sponsor @Edswald
            @Edswald 0_1493058241706_1493057570459-2017-04-24-120637_1280x1024_scrot.jpg
            And for future reference, past the contents of the config in text format on the forum, it will be easier to see all of the config file then.
            E 1 Reply Last reply
            • E
              Edswald @broberg
              @broberg is this right me an my team mate are here trying to see if we missed anything. Its still not running.0_1493061502651_2017-04-24-131726_1280x1024_scrot.png
                @Edswald post it as text. can’t help you with only a screenshot
                • E
                  Edswald @broberg
                  @broberg ok here you go
                  /* Magic Mirror Config Sample
                   * MIT Licensed.
                  var config = {
                  	port: 8080,
                  	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
                  	language: "en",
                  	timeFormat: 24,
                  	units: "metric",
                  			module: "alert",
                  			module: "updatenotification",
                  			position: "top_bar"
                  			module: "clock",
                  			position: "top_left"
                  			header: "US Holidays",
                  						symbol: "calendar-check-o ",
                  			module: "compliments",
                  			position: "lower_third"
                  			module: "currentweather",
                  				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                  			module: "weatherforecast",
                  			header: "Weather Forecast",
                  				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                  			module: "newsfeed",
                  				feeds: [
                  				maxNumTweets: 5,
                  				api_keys: {
                    You are using the wrong quotations,
                    you are using ’ when you should use '
                    and “ when you should use "
                    so first of change
                    ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
                    to
                    and
                    module: ‘twitControl’,
                    position: ‘top_left’,
                    maxNumTweets: 5,
                    streamType: ‘followings’,
                    api_keys: {
                    consumer_key: ‘ ’,
                    consumer_secret: ‘ ’,
                    access_token_key: ‘ ’,
                    access_token_secret: ‘ ’
                    to
                    module: "twitControl",
                    maxNumTweets: 5,
                    api_keys: {
                    consumer_key: ' ' ,
                    consumer_secret: ' ',
                    access_token_key: ' ' ,
                    access_token_secret: ' '
                    And do edit your post above to remove your personal keys!
                    • E
                      Edswald @broberg
                      @broberg Thank you very much it worked finally :)
                        @Edswald Glad to hear it!
                        • E
                          Edswald @broberg
                          @broberg umm can you help me again now im trying to install another twitter module with no luck :(
                          • E
                            Edswald
                            • MIT Licensed.
                            var config = {
                            port: 8080,
                            language: "en",
                            timeFormat: 24,
                            units: "metric",
                            		module: "alert",
                            		position: "top_bar"
                            		module: "clock",
                            		module: "newsfeed",
                            			feeds: [
                            maxNumTweets: 5,
                            api_keys: {
                            consumer_key: ‘fill’,
                            consumer_secret: ‘fill’,
                            access_token_key: ‘fill’,
                            access_token_secret: ‘fill’
                            module: ‘MMM-TwitterTrendsByPlace’,
                            position: ‘bottom_left’,
                            // visit the url below for the twitter keys/tokens
                            // https://dev.twitter.com/oauth/overview/application-owner-access-tokens
                            access_token_secret: ‘fill’,
                            // set the display name/title for the place
                            placeName: ‘New York, NY’,
                            // set the woeid for the place, see documentation for more
                            // http://woeid.rosselliot.co.nz/lookup/
                            placeWoeid: ‘2459115’,
                            if (typeof module !== “undefined”) {module.exports = config;}
                            • E
                              Edswald
                                @Edswald you have to place the modules within the brackets
                                If you go back to the picture where I marked that you should move two brackets you will see which ones I mean.
                                And when you post your config files delete your sensitiv data (like api-keyes)
                                • E
                                  Edswald @broberg
                                  @broberg Ahhh i see what you mean thank you again :)
