    Cant figure out how to install a module in the config.js
    19 Posts 5 Posters 14.2k Views 4 Watching
      broberg Project Sponsor @Edswald
      @Edswald 0_1493058241706_1493057570459-2017-04-24-120637_1280x1024_scrot.jpg
      And for future reference, past the contents of the config in text format on the forum, it will be easier to see all of the config file then.
      E 1 Reply Last reply
      • E
        Edswald @broberg
        @broberg is this right me an my team mate are here trying to see if we missed anything. Its still not running.0_1493061502651_2017-04-24-131726_1280x1024_scrot.png
        B 1 Reply Last reply
          @Edswald post it as text. can’t help you with only a screenshot
          • E
            Edswald @broberg
            @broberg ok here you go
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	port: 8080,
            	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
            	language: "en",
            	timeFormat: 24,
            	units: "metric",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            			header: "US Holidays",
            						symbol: "calendar-check-o ",
            			module: "compliments",
            			position: "lower_third"
            			module: "currentweather",
            				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
            			module: "weatherforecast",
            			header: "Weather Forecast",
            				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "New York Times",
            				showSourceTitle: true,
            				showPublishDate: true
            			module: 'twitControl',
            			position: 'top_left',
            				maxNumTweets: 5,
            				streamType: 'followings',
            				api_keys: {
              You are using the wrong quotations,
              you are using ’ when you should use '
              and “ when you should use "
              so first of change
              ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
              to
              and
              module: ‘twitControl’,
              position: ‘top_left’,
              maxNumTweets: 5,
              streamType: ‘followings’,
              api_keys: {
              consumer_key: ‘ ’,
              consumer_secret: ‘ ’,
              access_token_key: ‘ ’,
              access_token_secret: ‘ ’
              to
              module: "twitControl",
              maxNumTweets: 5,
              api_keys: {
              consumer_key: ' ' ,
              consumer_secret: ' ',
              access_token_key: ' ' ,
              access_token_secret: ' '
              And do edit your post above to remove your personal keys!
              • E
                Edswald @broberg
                @broberg Thank you very much it worked finally :)
                  @Edswald Glad to hear it!
                  • E
                    Edswald @broberg
                    @broberg umm can you help me again now im trying to install another twitter module with no luck :(
                    • E
                      Edswald
                      • MIT Licensed.
                      var config = {
                      port: 8080,
                      language: "en",
                      timeFormat: 24,
                      units: "metric",
                      		module: "alert",
                      		position: "top_bar"
                      		module: "clock",
                      		module: "newsfeed",
                      			feeds: [
                      maxNumTweets: 5,
                      api_keys: {
                      consumer_key: ‘fill’,
                      consumer_secret: ‘fill’,
                      access_token_key: ‘fill’,
                      access_token_secret: ‘fill’
                      module: ‘MMM-TwitterTrendsByPlace’,
                      position: ‘bottom_left’,
                      // visit the url below for the twitter keys/tokens
                      // https://dev.twitter.com/oauth/overview/application-owner-access-tokens
                      access_token_secret: ‘fill’,
                      // set the display name/title for the place
                      placeName: ‘New York, NY’,
                      // set the woeid for the place, see documentation for more
                      // http://woeid.rosselliot.co.nz/lookup/
                      placeWoeid: ‘2459115’,
                      if (typeof module !== “undefined”) {module.exports = config;}
                      • E
                        Edswald
                          @Edswald you have to place the modules within the brackets
                          If you go back to the picture where I marked that you should move two brackets you will see which ones I mean.
                          And when you post your config files delete your sensitiv data (like api-keyes)
                          • E
                            Edswald @broberg
                            @broberg Ahhh i see what you mean thank you again :)
