    Translations
    12 Posts 5 Posters 10.9k Views 5 Watching
    • Wilco89W Offline
      Wilco89
      Is it normaal use of uppercase in your language? And what is your language?
        Andrew
        sorry, I meant just the first letter. romanian
        Wilco89W 1 Reply Last reply Reply Quote 0
          Andrew
          look like monday, but i want to be Monday
          • Wilco89W Offline
            Wilco89 @Andrew
            @Andrew is it common in your language, to use uppercase in the middle of a sentence?
              Andrew
              in some cases yes. in MM the day near clock it’s apear with first letter lowercase. sorry for my english
              • KirAsh4K Offline
                KirAsh4 Moderator
                I have a feeling that’s simply the way the LOCALE is configured. When I look at the standard LOCALE files for the Romanian language, day names are all lower case. And Moment.js also returns it in lowercase. We don’t manipulate what the system tells it should be. I realize there are exceptions, such as at the start of a sentence, but since we follow the LOCALE standard, that’s why you see it in lowercase. Spanish day names are also all lowercase.
                  Andrew
                  I thought about it but I was not sure. thank you very much
                    arek123
                    thank you so much
                    http://www.piece-gastronomiczne.offset.net.pl/
                    • O Offline
                      opensky727 @KirAsh4
                      @KirAsh4 I know this topic is quite old, but would you know how to changed it to have capital letter in french also? I tried to modify the locale of fr and its not working.
                      KirAsh4K 1 Reply Last reply Reply Quote 0
                      • KirAsh4K Offline
                        KirAsh4 Moderator @opensky727
                        @opensky727, I haven’t touched MM in several months (other than the occasional git pull) so I’ll have to spend some time looking into it. In the mean time, if others can help, I’d appreciate it. Unfortunately I have one too many things going on at the same time here.
