Help with config and adding modules
Missing a coma right after and just before alert module and the starting bracket for the next module… :)
{ module: 'MMM-Facial-Recognition', config: { // 1=LBPH | 2=Fisher | 3=Eigen recognitionAlgorithm: 1, // Threshold for the confidence of a recognized face before it's considered a // positive match. Confidence values below this threshold will be considered // a positive match because the lower the confidence value, or distance, the // more confident the algorithm is that the face was correctly detected. lbphThreshold: 50, fisherThreshold: 250, eigenThreshold: 3000, // force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically) useUSBCam: false, // Path to your training xml trainingFile: 'modules/MMM-Facial-Recognition/training.xml', // recognition intervall in seconds (smaller number = faster but CPU intens!) interval: 2, // Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds logoutDelay: 15, // Array with usernames (copy and paste from training script) users: [], //Module set used for strangers and if no user is detected defaultClass: "default", //Set of modules which should be shown for every user everyoneClass: "everyone", // Boolean to toggle welcomeMessage welcomeMessage: true } }, { module: "alert", }, -
im sorry… but that did not help
could you show me the the lines as they should be?
https://pastebin.com/b6hpEDzc this might be easier to read
@mrfloppy88 That’s because I missed the starting bracket to the next module… I corrected it… try that :)
In the future to avoid issues backup your working config.js to config.bak because you know that works then add your module :)
Also put your config.js through this -> http://jshint.com/
It will tell you where your issue is :) -
thanks, yes i backup after every successfull edit ^^
damn, after that edit it just shows black
i tried the jshint, but i dont understand why it would be expecting some characters
are you familliar with the face recognition module?
@mrfloppy88 No, not at all. I’m sure someone here does. If you take it out and it works again I would leave it out and do some forum searching to see if others had the same issues :)
