    Help with config and adding modules
    7 Posts 2 Posters 2.5k Views 2 Watching
      mrfloppy88
      after trying to add a face recognition my config is broken
      can someone help me out?
      p.s. i had to use the sample file, as i broke the original config before
      i copied it to overwrite config.js and reapplied my edits
      /* Magic Mirror Config Sample
      • MIT Licensed.
      var config = {
      port: 8080,
      ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
      language: "nl",
      timeFormat: 24,
      units: "metric",
      		module: 'MMM-Facial-Recognition',
      			// 1=LBPH | 2=Fisher | 3=Eigen
      			recognitionAlgorithm: 1,
      			// Threshold for the confidence of a recognized face before it's considered a
      			// positive match.  Confidence values below this threshold will be considered
      			// a positive match because the lower the confidence value, or distance, the
      			// more confident the algorithm is that the face was correctly detected.
      			lbphThreshold: 50,
      			fisherThreshold: 250,
      			eigenThreshold: 3000,
      			// force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
      			useUSBCam: false,
      			// Path to your training xml
      			trainingFile: 'modules/MMM-Facial-Recognition/training.xml',
      			// recognition intervall in seconds (smaller number = faster but CPU intens!)
      			interval: 2,
      			// Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
      			logoutDelay: 15,
      			// Array with usernames (copy and paste from training script)
      			users: [],
      			//Module set used for strangers and if no user is detected
      			defaultClass: "default",
      			//Set of modules which should be shown for every user
      			everyoneClass: "everyone",
      			// Boolean to toggle welcomeMessage
      			welcomeMessage: true
      		module: "alert",
      		module: "updatenotification",
      		position: "top_bar"
      		module: "clock",
      		position: "top_left"
      		header: "Feestdagen",
      					symbol: "calendar-check-o ",
      					url: "webcal://ical.mac.com/ical/Dutch32Holidays.ics"
      		module: "compliments",
      		position: "lower_third"
      		module: "currentweather",
      			locationID: "2759040",  //ID from http://www.openweathermap.org/help/city_list.txt
      			appid: "XXX"
      		module: "weatherforecast",
      		header: "Weather Forecast",
      			appid: "XXX"
      		module: "newsfeed",
      		position: "bottom_bar",
      			feeds: [
      					title: "Eindhovens Dagblad",
      					url: "http://www.ed.nl/best-e-o/rss.xml"
      			showSourceTitle: true,
      			showPublishDate: true
      if (typeof module !== “undefined”) {module.exports = config;}
      • cowboysdudeC Offline
        Missing a coma right after and just before alert module and the starting bracket for the next module… :)
        		lbphThreshold: 50,
        		useUSBCam: false,
        		interval: 2,
        		logoutDelay: 15,
        		users: [],
            module: "alert",
          mrfloppy88
          im sorry… but that did not help
          could you show me the the lines as they should be?
          https://pastebin.com/b6hpEDzc this might be easier to read
            cowboysdude Module Developer @mrfloppy88
            @mrfloppy88 That’s because I missed the starting bracket to the next module… I corrected it… try that :)
            In the future to avoid issues backup your working config.js to config.bak because you know that works then add your module :)
            Also put your config.js through this -> http://jshint.com/
            It will tell you where your issue is :)
              mrfloppy88
              thanks, yes i backup after every successfull edit ^^
                mrfloppy88
                damn, after that edit it just shows black
                i tried the jshint, but i dont understand why it would be expecting some characters
                are you familliar with the face recognition module?
                https://pastebin.com/640sLwqB
                  @mrfloppy88 No, not at all. I’m sure someone here does. If you take it out and it works again I would leave it out and do some forum searching to see if others had the same issues :)
