Help with config and adding modules
im sorry… but that did not help
could you show me the the lines as they should be?
https://pastebin.com/b6hpEDzc this might be easier to read
@mrfloppy88 That’s because I missed the starting bracket to the next module… I corrected it… try that :)
In the future to avoid issues backup your working config.js to config.bak because you know that works then add your module :)
Also put your config.js through this -> http://jshint.com/
It will tell you where your issue is :) -
thanks, yes i backup after every successfull edit ^^
damn, after that edit it just shows black
i tried the jshint, but i dont understand why it would be expecting some characters
are you familliar with the face recognition module?
@mrfloppy88 No, not at all. I’m sure someone here does. If you take it out and it works again I would leave it out and do some forum searching to see if others had the same issues :)
