Starting/monitoring remotely
4 Posts 3 Posters 3.3k Views 3 Watching
    amanzimdwini
    Probably something I should know, but
    I am in the process of customizing my MM2 - and I am NOT in front of it.
    So I RDP over to it on one of my monitors, start a terminal and launch MM.
    Since I am now locked out, I have to use PUTTY to work on it on a different monitor.
    i change stuff and then sudo reboot. Every time.
    There must be a better way of stopping and starting MM2.
    Help?
    Thanks!
      Bangee Module Developer
      if you are loged in on putty, you can restart your mirror using this command:
      pm2 restart mm
      or you’ll have to install a VNC Server on Raspberry to display your screen remotly.
      https://www.google.ch/search?q=raspberry+pi+vnc+server+autostart&ie=utf-8&oe=utf-8&client=firefox-b&gfe_rd=cr&ei=hdJ0V-eKPOLI8geiy5igDg
      And then you’ll be able to reload the mm pushing CTRL + R
      A 1 Reply Last reply Jun 30, 2016, 10:12 PM Reply Quote 0
        amanzimdwini @Bangee
        @Bangee
        THAT was easy (duh)
        Thanks. How do I mark this as closed/resolved?
          paviro Admin
          I did it for you :) But you can also find it here:
          – The Doctor
