    Sachin's Mirror
    30 Posts 5 Posters 31.3k Views 7 Watching
      amanzimdwini @KirAsh4
      @KirAsh4
      Now I have question that is probably painfully obvious to anyone but me (I’m an old physicist and drive around in SQL all day long – don’t ask; I have no idea about hardcoding CSS.)
      IF I want to change the font of, say, the compliments,
      THEN I poke around and see that part of compliments.js
          var compliment = document.createTextNode(complimentText);
          wrapper.className = "thin xlarge bright";
      Cool: I could redefine, say, xlarge in my custom.css. But that seems a silly hack, and I’d mess up everything else that also uses xlarge. Not good. Much better to change the color of compliments only. How do I do that? Say I want
      compliments
      .color: #3CF
      .font-size: 80px
      .line-height: 80px
      .font.family: "Ariel"
      I suspect that this is very obvious how to change my custom.css, but you guys all seem helpful :)
      Hey: I already figured out how to push things around on the screen to where I want them to be. Next, I have to stretch everything, since the fonts seem a bit compressed. Lots of fun. Ultimately I’ll write my own modules, I hope.
      Thanks in advance!
      W 2 Replies Last reply Reply Quote 0
      • W Offline
        Wilco89 @amanzimdwini
        @amanzimdwini, open Magic Mirror in a browser yourip:8080,
        Right click (inspect element) and look for the right class name (that is the one to use).
          amanzimdwini @Wilco89
          @Wilco89
          Thanks. Am an old male - need EXPLICIT instructions :)
          • W Offline
            @amanzimdwini
            Css should like this:
            .compliments{
            color: #3CF,
            Etc: 80px,
            etc: 80px,
            fontfamily: Ariel,}
              @Wilco89
              WOAH - I was really close. (and I was just guessing!). (looking at inspect elements gave me a headache)
              Thanks! I;ll try it right now
              • K Offline
                KirAsh4 Moderator
                You can be very specific which tag you are trying to change, even if it’s one that is used everywhere. For example, let’s say I want to change the CSS for 'bright'. Just about all the modules use that tag, so if I change it, it’s going to affect all of them. But what if I want to only affect the calendar module? You can use the DOM tree to your advantage. If you look at the elements tree you should see something similar to this:
                <div class="region top left">
                  <div class="container">
                    <div id="module_1_clock" class="module clock clock">...</div>   <== this pertains to the clock only
                    <div id="module_2_calendar" class="module calendar calendar">   <== this pertains to the calendar only
                      <div class="module-content">
                        < --some random tag that uses the class 'bright' in here-- >
                      </div>
                    </div>
                  </div>
                </div>
                Now I can see that the 'bright' tag that I want to change, has several parent tags above it. Since I only want to affect the calendar one, I can then create a CSS rule that says:
                .module.calendar .bright {
                  color: #ff0000;
                This says, to specifically look for the element that has the "module calendar" class, then within that, look for anything that uses the class "bright".
                Now only my calendar is affected (and shows red text). Now just for grins, remove the first part, and just make it
                .bright {
                  color: #ff0000;
                And you’ll notice all of your text is now red. By adding the specific parent class or ID, you can be very specific which class you’re targeting.
                Happy hacking!
                W A 2 Replies Last reply Reply Quote 0
                • W Offline
                  Wilco89 @KirAsh4
                  @KirAsh4 thnx, i’m on my phone so really hard to type Long text.
                    @KirAsh4 @Wilco89
                    I really appreciate the help (and it works!)
                    While I’m at it: just so that I understand: since compliments.js references thin xlarge bright I could have changed any of those three? They were referenced, so I can overwrite them? Ie in my custom.css:
                    .module.compliments.bright {
                      color: #ff0000;
                    or
                    .module.compliments.xlarge{
                      color: #ff0000;
                    would/should both in effect do the same thing?
                    Or can I just change EVERYTHING in compliments to be color: #ff0000? ie
                    .module.compliments{
                      color: #ff0000;
                    (which I tried, and it did not work :( )
                    • K Offline
                      KirAsh4 Moderator
                      You’re missing the required space. You’re dealing with two separate tags, with multiple CSS rules applied. So when creating a new rule, you have to do the same:
                      .module.compliments .xlarge  <--- notice the space
                      Without the space, it’s looking for a single tag that has all three rules applied, so it’s looking for class="module compliments xlarge". When you add the space, it’s now looking for two separate tags, a parent tag that has a class with both "module compliments" as rules, and then a child tag that has a class with "xlarge" for a rule.
                      Does that make sense?
                      • W Offline
                        @amanzimdwini
                        .module.compliments .bright {
                        color: #ff0000;
                        Should work. (Don’t forget the space)
                          @KirAsh4
                          THANKS! (major lightbulb).
                          Happy 4th to you and @Wilco89
