    Sachin's Mirror
    30 Posts 5 Posters 32.6k Views 7 Watching
      Sachin
      Thanks everyone. Per KirAsh4’s suggestion. I’m going to upload a sanitized copy on Github. I’d still encourage everyone to read through the install docs so you know where/how to tweak it to your liking. I’ll try to get to it this weekend.
      Have a great 4th!
      • K
        KirAsh4 Moderator
        Changing any of the module’s color settings is done in the '~/MagicMirror/css/custom.css' file. This is assuming the author of the module wrapped the various elements in tags that you can refer to, which all of the default modules are. You can look at the 'main.css' file to get an idea of what the various tags are that you can use. I do not recommend changing anything in 'main.css', but rather override them in 'custom.css' instead.
        Alternatively you can also look at the raw HTML generated through your browser’s console (just pulling up the page’s source won’t show the full HTML generated.)
        A 2 Replies Last reply
        • A
          amanzimdwini @KirAsh4
          @KirAsh4
          THX. Will spend some happy time fiddling with all the stuff. “Wasted” 2 days on getting MM2 up on a brand-new Pi3, but the ‘wife-acceptance-factor’ is already awfully high :) Now I have to just customize it to the n-th degree…
          • K
            KirAsh4 Moderator
            Nothing’s ever “wasted”. You learned a lot during that time … educational enrichment. :)
            • A
              @KirAsh4
              Now I have question that is probably painfully obvious to anyone but me (I’m an old physicist and drive around in SQL all day long – don’t ask; I have no idea about hardcoding CSS.)
              IF I want to change the font of, say, the compliments,
              THEN I poke around and see that part of compliments.js
                  var compliment = document.createTextNode(complimentText);
                  wrapper.className = "thin xlarge bright";
              Cool: I could redefine, say, xlarge in my custom.css. But that seems a silly hack, and I’d mess up everything else that also uses xlarge. Not good. Much better to change the color of compliments only. How do I do that? Say I want
              compliments
              .color: #3CF
              .font-size: 80px
              .line-height: 80px
              .font.family: "Ariel"
              I suspect that this is very obvious how to change my custom.css, but you guys all seem helpful :)
              Hey: I already figured out how to push things around on the screen to where I want them to be. Next, I have to stretch everything, since the fonts seem a bit compressed. Lots of fun. Ultimately I’ll write my own modules, I hope.
              Thanks in advance!
              W 2 Replies Last reply
              • W
                Wilco89 @amanzimdwini
                @amanzimdwini, open Magic Mirror in a browser yourip:8080,
                Right click (inspect element) and look for the right class name (that is the one to use).
                A 1 Reply Last reply
                • A
                  amanzimdwini @Wilco89
                  @Wilco89
                  Thanks. Am an old male - need EXPLICIT instructions :)
                  • W
                    @amanzimdwini
                    Css should like this:
                    .compliments{
                    color: #3CF,
                    Etc: 80px,
                    etc: 80px,
                    fontfamily: Ariel,}
                    • A
                      @Wilco89
                      WOAH - I was really close. (and I was just guessing!). (looking at inspect elements gave me a headache)
                      Thanks! I;ll try it right now
                      • K
                        KirAsh4 Moderator
                        You can be very specific which tag you are trying to change, even if it’s one that is used everywhere. For example, let’s say I want to change the CSS for 'bright'. Just about all the modules use that tag, so if I change it, it’s going to affect all of them. But what if I want to only affect the calendar module? You can use the DOM tree to your advantage. If you look at the elements tree you should see something similar to this:
                        <div class="region top left">
                          <div class="container">
                            <div id="module_1_clock" class="module clock clock">...</div>   <== this pertains to the clock only
                            <div id="module_2_calendar" class="module calendar calendar">   <== this pertains to the calendar only
                              <div class="module-content">
                                < --some random tag that uses the class 'bright' in here-- >
                              </div>
                            </div>
                          </div>
                        </div>
                        Now I can see that the 'bright' tag that I want to change, has several parent tags above it. Since I only want to affect the calendar one, I can then create a CSS rule that says:
                        .module.calendar .bright {
                          color: #ff0000;
                        This says, to specifically look for the element that has the "module calendar" class, then within that, look for anything that uses the class "bright".
                        Now only my calendar is affected (and shows red text). Now just for grins, remove the first part, and just make it
                        .bright {
                          color: #ff0000;
                        And you’ll notice all of your text is now red. By adding the specific parent class or ID, you can be very specific which class you’re targeting.
                        Happy hacking!
                        W A 2 Replies Last reply
                        • W
                          Wilco89 @KirAsh4
                          @KirAsh4 thnx, i’m on my phone so really hard to type Long text.
                          • A
                            @KirAsh4 @Wilco89
                            I really appreciate the help (and it works!)
                            While I’m at it: just so that I understand: since compliments.js references thin xlarge bright I could have changed any of those three? They were referenced, so I can overwrite them? Ie in my custom.css:
                            .module.compliments.bright {
                              color: #ff0000;
                            or
                            .module.compliments.xlarge{
                              color: #ff0000;
                            would/should both in effect do the same thing?
                            Or can I just change EVERYTHING in compliments to be color: #ff0000? ie
                            .module.compliments{
                              color: #ff0000;
                            (which I tried, and it did not work :( )
                            W 1 Reply Last reply
                            • K
                              KirAsh4 Moderator
                              You’re missing the required space. You’re dealing with two separate tags, with multiple CSS rules applied. So when creating a new rule, you have to do the same:
                              .module.compliments .xlarge  <--- notice the space
                              Without the space, it’s looking for a single tag that has all three rules applied, so it’s looking for class="module compliments xlarge". When you add the space, it’s now looking for two separate tags, a parent tag that has a class with both "module compliments" as rules, and then a child tag that has a class with "xlarge" for a rule.
                              Does that make sense?
                              • W
                                @amanzimdwini
                                .module.compliments .bright {
                                color: #ff0000;
                                Should work. (Don’t forget the space)
                                • A
                                  @KirAsh4
                                  THANKS! (major lightbulb).
                                  Happy 4th to you and @Wilco89
