npm do not start!
We need a little more info to help.
- Are you booting in CLI mode, or in the GUI mode (and starting this from a terminal window)?
 - What’s the Node version you’re running?
 - What RPi are you using?
 - What OS are you using?
Hi MichMich,
Yes i start with my terminal.
My node.js version is 6.2.2.
My OS is jessie
My RPi is RPi0Thanks
Are you using the term “terminal” as the actual Term app installed in the graphical environment, or as a command line environment? Meaning, when you boot up the rpi, does it boot up in the graphical screen, or does it stop at a black (text) screen that you log in to?
When starting the GUI terminal and the commande “npm start” the script starts. I have a progress bar and after a few seconds the script stops. No interface starts. Node.js 6.2.2 is installed and the dependencies are ok too.
@Neokamikaze The zero isn’t supposed at the moment, is it? @KirAsh4
