    Pushbullet
    17 Posts 2 Posters 14.2k Views 4 Watching
    • W Offline
      Wilco89
      Is there an possibility to make an module for pushbullet?
        A Former User
        what’s pushbullet?
        • W Offline
          Wilco89
          Pushbullet can show your notifications on other devices (http://pushbullet.com) i think there is an api but my knowledge is not very good about API’s
          When someone thinks it can work i will try to start and start to learn something about it.
            A Former User
            https://docs.pushbullet.com/
            Their API looks pretty good… What do you want to achieve? Just show the the notifications?
            • W Offline
              Wilco89
              I would like to see notifications on my mirror, so i can see why telephone is ringing when i’m not with my phone etc.
              • K Offline
                KirAsh4 Moderator
                I have a question you may or may not have thought about @Wilco89: what happens if you aren’t looking at the mirror when you get a notification? And if you plan on having the notification sit on screen till you dismiss it, how do you plan on doing that?
                Alerts and notifications are great, if you are there to see them. But once they timeout, they disappear and you never saw it. Or are you including a button of sorts to dismiss notifications?
                  paviro
                  You could use the default notification module :) but it’s true right now there is no way to check missed ones should probably be added to the default one as well somehow :)
                  – The Doctor
                  • K Offline
                    KirAsh4 Moderator
                    Now, a touch screen, that would be fun to use and dismiss things, or move modules around or … or … or … ok, my head’s going to explode if I keep thinking about this. Too many ideas, so little time (or none at all.)
                    • W Offline
                      Wilco89
                      Fiets off All i’m gonna use 2 modules of @paviro the pir sensor (when it is working) so no movement no display, and i’m gonna use facial reg. So only i will see my notifications.
                      When i’m away the notifications can disapear because i will see them on my phone. But when i’m in front of the mirror doing my Hair. i will got really dirty hands so when a notifications will pop up i can see if it is important. That is option 1.
                      Or a module with a button so you can swipe or Push them away. Maybe is the swipe module useable for that?
                      • K Offline
                        KirAsh4 Moderator
                        So I have this image of you standing in front of your mirror and a notification shows up … I have an idea for dismissing them: install a kick button. So you can just kick it. Works great when you get a not-so-friendly notification. :)
                        • W Offline
                          Wilco89 @KirAsh4
                          @KirAsh4
                          Just did a test on my Computer, but there is an option there to show the notification for just 30 seconds and hides after it. that should be log enough to read the most whatsapp messages etc.
                          • K Offline
                            KirAsh4 Moderator
                            A long time ago in a galaxy far, far away… I used to care to get those notifications as soon as they arrived.
                            • W Offline
                              Wilco89
                              I never used an API before does somebody have some tips/tricks for me?
                              • K Offline
                                KirAsh4 Moderator
                                A lot of reading?
                                API are created to expose certain hooks that you can tie to. So check out the API’s documentation and figure out how to call it. For example, the default weather module uses the OpenWeatherMap API. If you look at the web site’s API page, you will see explanations of how to send your request for information. In this case, it’s a simple http:// call. So in the 'node_helper.js' file, you can then see how the URL is generated and then send out to the API hook. It then waits for data to return and pass it back on to the weather module.
                                  ronny3050 Module Developer @Wilco89
                                  @Wilco89 How far are you with this? I was wondering whether I could take a crack at it.
                                    Finished with the module. https://forum.magicmirror.builders/topic/477/phone-notifications
                                    Please let me know if this solves your request!
                                    • W Offline
                                      Wilco89
                                      Thnx @ronny3050!
                                      having a busy holiday. did not get any furtfer. nut it seams like a good option for me, will try to get it to work on my screen asap.
