    Weather forecast from current location/calendar location
    11 Posts 0 Posters 8.3k Views 3 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      Adding a GPS will add more code, yes. And you’d also have to figure out how to tell it to get an area location, as opposed to a pin-point location (which a GPS is excellent at.)
      • E Offline
        EoinOG
        Amazing, Thanks for the responses guys. Is this something easily achievable? And if so, where should I start? I’m a noob to code.
        mochmanM 1 Reply Last reply Reply Quote 0
        • Wilco89W Offline
          Wilco89
          I can’t help you with that, i’m a noob in coding JS. but i think first of all is to look if there is an GPS module you can use for the raspberry
          • mochmanM Offline
            mochman Module Developer @EoinOG
            @EoinOG I made something similar to what you want. It takes a GPS location from your phone and updates a webpage that the raspberry pulls in and give you weather in that location.
            MMM-GPSWeather
            • E Offline
              EoinOG
              This is amazing. Thanks so much @mochman. Is there any more documentation anywhere to guide me through installing it?
              • mochmanM Offline
                @EoinOG I can make some up for you. How far have you gotten with the installation?
                • E Offline
                  EoinOG
                  I’ve installed the module. But don’t know where to go from here with regards the configuration of it.
                  • mochmanM Offline
                    I updated this module page with a step-by-step’ish guide on how to install and configure the module. Let me know if you run into any issues.
                    Since the module pulls lat/long data in JSON format from a file, you could just manually edit that file to update your location. This is in case you don’t want to use the GPS tracker on your phone.
                    What this means is that if you want to tweak the code, you could just have a file on your raspberry pi, or somewhere else on your home network that the lat/long is pulled from instead of setting up a website.
