    Error during installation of MM2
    5 Posts 3 Posters 3.7k Views 3 Watching
    • rudibaraniR Offline
      rudibarani Project Sponsor
      I frequently experience the following errors when installing MM2:
      Installing MM2 using
      curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
      always leads to the following error message
      MagicMirror installation successful!
      npm notice created a lockfile as package-lock.json. You should commit this file.
      npm WARN grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
      npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
      added 568 packages in 655.466s
      Dependencies installation Done!
      Check plymouth installation ...
      Splashscreen: Checking themes directory.
      Splashscreen: Create theme directory if not exists.
      Splashscreen: Theme copied successfully.
      Splashscreen: Changed theme to MagicMirror successfully.
      bash: Zeile 153: Syntaxfehler beim unerwarteten Wort `then'
      bash: Zeile 153: `then'
      I am using a RasPi with Jessie and node v6.10.3.
      MM2 seems to work fine afterwards, but maybe we could eliminate this error message?
      • cowboysdudeC Offline
        Go with the manual install here:
        Manual Installation
        Download and install the latest Node.js version.
        Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
        Enter the repository: cd ~/MagicMirror
        Install and run the app: npm install && npm start
        Important: npm start does not work via SSH, use DISPLAY=:0 nohup npm start & instead. This starts the mirror on the remote display.
        Note: if you want to debug on Raspberry Pi you can use npm start dev which will start the MagicMirror app with Dev Tools enabled.
          Thanks for the advice. I will give it a try.
          As it always run fine despite the error messages, I was more concerned about the user experience when using the promoted way to install it.
            cowboysdude Module Developer @rudibarani
            @rudibarani said in Error during installation of MM2:
            If it runs fine then ignore the error messages. From time to time error messages occur and at times really aren’t major. As long as it’s running and working fine that’s okay ;)
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @rudibarani
              @rudibarani the command you used to install MM is deprecated.
              Use bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)" instead.
