    MMM-Todoist - Your todoist tasks on your mirror
    76 Posts 37 Posters 117.7k Views 39 Watching
      Sunburned @MasonT3
      @MasonT3
      Thanks for the suggestion, saw that earlier in the thread and tried it out. No luck
        Sunburned @dakipro
        @dakipro
        Just a tip, todoist now integrates natively with google calendar, then the “official” calendar plugin works just fine.
        (even before todoist integrated with google, i used todoist iCal link with official calendar plugin, set manual refresh and it just works great).
        Is that only available to premium users?
          dakipro
          yeah, looks like it, didn’t think of that to be honest :(
            Sunburned
            General question then. Do you need a premium todoist account for this module to function? I don’t see why you would but i cant think of another explanation.
            • T
              tkotz8621 @Sunburned
              @Sunburned No you do not need the premium Todoist account for the module to work.
              • T
                tkotz8621 @MasonT3
                @MasonT3 I wrote a fix to the ‘no due date tasks’ so they will sort to the end. I think Chris Booker hasn’t had time to implement but the fix is available at my MMM-Todoist fork at: https://github.com/tkotz8105/MMM-Todoist
                • T
                  @Sunburned I wrote a fix to the ‘no due date tasks’ so they will sort to the end. I think Chris Booker hasn’t had time to implement but the fix is available at my MMM-Todoist fork at: https://github.com/tkotz8105/MMM-Todoist
                    Sunburned
                    So i have tried:
                    1. Updating the fetcher from https://github.com/tkotz8105/MMM-Todoist
                    2. Putting my list number in the MMM-Todoist.js file rather than the config file (my list number is 10 digits btw, not an issue but i thought it was odd as all the samples had 9.)
                    3. Changing the Access token
                    4. Deleting and recreating the module
                    5. Deleting my todoist account and recreating it
                    I am currently at a loss.
                      Sunburned
                      So the plot thickens. I have a cron job that restarts my mirror at 2am every day. I get home from work today and my mirror shows the 2 test entries I made when setting up my new todoist account, but they will not update. So those entries will not be removed and new entries will not be added, even when restarting the mirror.
                        Chiumanfu
                        Do those two entries have due dates associated? Mine did some weird things until I assigned due dates to each entry… and subsequently added tkotz8105’s fetcher fix.
                        • T
                          tkotz8621
                          @Sunburned I find that sometimes happens as well… some changes I make (deletions, additions, mods) don’t make it to the mirror. I do not know why that is happening and have not looked in any detail on it. When you say that you restart the Mirror at 2 am… is it a system reboot? I do the same and when it all starts back up… the tasks are there and properly sorted.
                            Sunburned
                            Thanks for the responses everyone.
                            Chiumanfu
                            Yep the entries all had due dates, and I also did the fetcher fix.
                            tkotz8621
                            2am is a full system reboot of the raspberry pie that then restarts the mirror.
                            • joela85J
                              joela85 @Sunburned
                                Sunburned
                                So finally progress. I noticed that when the mirror was starting i was getting that EADRINUSE :::8080 error. I dug around a bit and removed some old modules that I either didn’t want anymore or decided not to use and flushed the PM2 logs, no more error on loading and todoist is working.
                                The only issue now is the same thing that used to happen with wunderlist. If i add items to the list, they get added fine. If i remove them they do not come off. But if I remove something and add something else the removed item will be removed when the new item appears.
                                  ROMSY
                                  hey guys,
                                  just a short question is it possible to just show up the Tasks of Today or the next seven days or does only “One” list in the Module work right now?
                                    djsunrise19 @tidus5
                                    @tidus5 Looks nice! Could you please share your code? :)
                                      Blackmirror
                                      I can’t see my entrys, but for two weeks as was functional.
                                      My list is now only empty
                                      • T
                                        tkotz8621
                                        Mine too. I wonder if Todoist API was changed. I was planning to look at it but unfortunately it won’t be until the weekend.
                                          Blackmirror
                                          I have my make a new api , but it is not working too.
                                          • kruemelK
                                            kruemel
                                            • 3 / 4
