    Wunderlist, blank screen when Wunderlist module is added to config.js
    9 Posts 4 Posters 4.8k Views 4 Watching
    • N Offline
      NathTheDude
      Hey,
      I am having issues with the ‘MMM-Wunderlist’ and the enhanced version, when I add this in as a modules, then reboot the rpi. All I get is a blank screen? When I ssh in and then remove the module from the config.js, reboot then everything is back again. It does not seem to matter what I add the module config I get the same results.
      Nathan
      • KimzerK Offline
        Kimzer
        Maybe you are missing a semicolon somewhere :)
        • N Offline
          NathTheDude
          @Kimzer Hmmmm, maybe. From the times I have missed/messed up config if normally comes up with something like …missing config.js
          • KimzerK Offline
            Kimzer
            Post some of ur config.js so we can see if there is a problem.
            With the module causing problems in ofcorse.
            • N Offline
              NathTheDude
              @Kimzer Thanks for your quick replies. I deleted the Wunderlist and the enhanced Wunderlist folders/modules. Then created the Wunderlist folder again, then did npm install and this seems to have resolved the issue, must of been a problem with the Module.
              • KimzerK Offline
                Kimzer
                Great, glad u got it working :D
                • ceddirrC Offline
                  ceddirr
                  Same thing is happening to me, but just installed the enhanced folder.
                  npm install is going bad :
                  pi@mirror:~/MagicMirror/modules $ npm install
                  npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
                  npm WARN modules No description
                  npm WARN modules No repository field.
                  npm WARN modules No README data
                  npm WARN modules No license field.
                  Any idea?
                  Did you just re install the standard folder instead of the enhanced one to solve your problem, please?
                  Thank you for your help!
                  Cedric
                  randomnoiseR 1 Reply Last reply Reply Quote 0
                  • randomnoiseR Offline
                    randomnoise @ceddirr
                    @ceddirr looks like you’re running npm install from the modules directory, you probably want to cd in to the wunderlist folder (which itself is in modules) then run the npm install
                    ceddirrC 1 Reply Last reply Reply Quote 1
                    • ceddirrC Offline
                      ceddirr @randomnoise
                      @randomnoise Thank you very much!
                      I didn’t know that, but it makes sense!
                      It is working now =)
